Hi, Apologies if this is the wrong place. can anyone recommend someone to code out the following on my ecu? I have a mk3 golf i have completed a conversion in, (AUM), I had the ecu remapped and de immobilised previously but didnt have the following coded out, it does have a map on it which im happy with but get these code showing up constantly. 17931 - P1523 CRASH SIGNAL FROM AIRBAG CONTROLLLER IMPLAUSABLE SIGNAL 18057 - P1649 POWERTRAIN DATA BUS MISSING MESSAGE FROM ABS CONTROLLER 18058 - P1650 POWERTRAIN DATA BUS MISSING MESSAGE FROM INSTRUMENT CLUSTER 17834 - P1426 EVAP PURGE VALVE N80 - OPEN CIRCUIT 17956 - P1548 BOOST PRESSUSRE REGULATION VALVE N75 OPEN CIRCUIT 17841 - P1433 SECONDARY AIR PUMP RELAY J299 OPEN CIRCUIT 17840 - P1432 SECONDARY AIR INJECTION SOLENOID VALVE N112 OPEN CIRCUIT 17695 - P1287 BOOST PRESSURE CONTROL VALVE OPEN CIRCUIT I think i recall seeing P1200 N249 Mechanical malfunction - but i did plug this is at some point so maybe related to that. I didnt have the code for the secondary Lambda sensor when i last scanned the car but would ideally like that removed too as i only have the first one installed. I have looked at dumping a resistor in some of them but i dont think its as reliable as having them coded out properly. I think a couple of them are CAN related but would like it as clean as possible, many recommendations or help would be awesome!
Toyotec on here, AKA Adlai Phillip on Facebook, or you can try Chris Bellman on FB as well you have a code for the N75 which needs looking at though, the wiring to it may be damaged it can happen due to the routing of it
brilliant, thank you, I messaged Toyotec so hopefully hear back soon. thanks again, Ill have to take a look at the N75.
