MK2 clocks into a mk1 dash?
Discussion in 'Electrical' started by VWJ1M, Mar 28, 2005.
  1. VWJ1M Forum Member
    Is it possible to put the mk2 clocks into a mk1 dash???
  2. Tarmac Terror Forum Member
    Yes it is possible. Its easier to fit the clocks with the single plug setup for the loom, but may need to move the wiring in the plug. The doubnle plug type can also be done but needs more wire fiddling.
    Also, if yo get the really early MK1 clocks, you dont; need to worry about changing the steering column satlk for the MK2 type as the early ones have the reset button like the MK1 clocks.
  3. VWJ1M Forum Member
    Cheers
    So they fit in ok?
    Just need to sort out the wiring then. any on line websites?
  4. Tarmac Terror Forum Member
    The lugs on the side I think are slightly different, you might need to make up some small brkts for the side fixings, but it shouldn't need anything more. I'm not aware of any on line websites showing the wiring. Might have something in an old Rabbit but its a real long shot as nothing springs to mind. If I remember rightly the flexi printed circuit board has the words in german saying whaqt each track is used for (long time since I've looked though, but I'me sure it has from memory)
  5. VWJ1M Forum Member
    Thanks V Much, will look into it sooon
  6. Brookster
    M1 J40
    click on search and "16v clocks" theres a wiring diagram on there from harry the cake ;)
    Edited by: Brookster
  7. VWJ1M Forum Member
    Ok, My dash is apart for the second time this week!! ahhh.
    The MK2 clocks will not fit into the mk1 dash. any advice?
    Ive got them to sit on the bars at the back but when tilting back to screw in, the top of the clocks hit the dash. [:^(]
  8. Brookster
    M1 J40
    snap that's what i got with mine, any ideas anybody, plus the oil light stays lit and so does the water temp light [:^(]
  9. Brookster
    M1 J40
    wiring diagram ;) [​IMG]
  10. VWJ1M Forum Member
    i just got my dash back together, and there are no squeeks or rattles!!!! :p :) [:D]
    So im going to leave it for a while.
    But i have a plan, im going to remove the dash AGAIN, and then fit the dials in. this should give me a better idea of the brackets needed.
    Also its easy to work with, than sitting forward and getting a pain in my back!
    The dials will fit, but moderate modification is required.The pegs will need to be removed.
  11. DarrenW Forum Junkie
    Mine has got Mk2 clocks in it, something to do with the 16v conversion apparently... I know that's no help but I just thought I'd mention it :lol:
  12. VWJ1M Forum Member
    Have you had a look into how the clocks are attached in?
  13. TIM
    Tim Forum Addict
    probably what i should do, that would be why im having problems with mine, (have a look at my thread in engine,)
    tim,
  14. Brookster
    M1 J40
    Any photo's of a mk2 clock install into a mk1 anyone [8(]
  15. black_cabbie Forum Member
    Belgium
    Voila!
    Wiring table....
    Pin on Single 28 pin Plug / Color on Big Plug, Description / Color on MK2 CE1 Harness
    2 Red/White Coolant Low Level Sensor (Blue/Yellow)
    3 Brown Ground
    4 Grey MFA RESET
    5 Brown/White MFA GROUND (Brown)
    6 Green/White MFA MEMORY (Grey/Yellow)
    7 Violet Speed Sensor (Blue/White)
    8 Yellow Oil Pressure Control Unit 1.8 Bar (Gray/White)
    9 Red/White Oil Pressure Control Unit 0.3 Bar (Blue/Black)
    10 Green Tachometer (Red/Black)
    11 Red Digital Clock (Red/White)
    12 GreyInstrument Panel Lighting (Gray/Blue)
    13 Black ignition switch (Yellow/Red)
    15 Black MFA MODE SWITCH (Green/Black)
    16 Blue Alternator Warning Light (Blue)
    17 Black/White Engine Oil Temp (Green/Black) MFA
    18 Yellow Seat Belt Indicator
    19 Violet Outside Temp Sensor (Black) MFA
    21 Blue Fuel Gauge (Violet/Black)
    23 Yellow/Red Coolant Temp Gauge (Blue/Yellow)
    24+22 Green+Brown/White Turn Signal Light (Green/Black) Join them together
    25 White High Beam Indicator light (Black/White)
    For CE1 dual plug cluster match color to color and swap the two oil pressure switches.
