Mk2 golf g60 RHD throttle cable
Discussion in '8-valve' started by J-dog G60, Sep 18, 2021.
  1. J-dog G60 New Member
    Hi which is the correct throttle cable to use ? Part numbers please ,and can I buy one from ?
    mk2 gti will fit fine, available from all over. try to get GEMO make if you can, 192721555A
  3. J-dog G60 New Member
    Hi it think that’s what I’ve got already, and it’s to long ?
    have a look for any part numbers, a carb one would be way too long gti much shorter. how much longer are we talking, bearing in mind a RHD GTI has throttle body on driver side near brake servo
  5. J-dog G60 New Member
    Ok mate thanks I will have a look and see if i can find a part number and get back to you
  6. J-dog G60 New Member
    Hi it says it a Gemo cable part number on it is 434792? It’s 1084mm long which is a gti one isn’t it ?
  7. rubjonny
    OK that comes back to GTI cable yep, so pretty much the shortest there is :( when you say its too long, is it just the routing or is it not operating the throttle properly
  8. J-dog G60 New Member
    Oh rite ok ,it’s not operating the throttle correctly, it’s nearly on full adjustment
  9. rubjonny
    right, what it could be is your pedal is bent, easy done if the linkage was set to tight in the past. easy enough to bend it back, hold the cable rod up the top then pull the pedal up towards you. while there make sure the rod is pulling the cable directly thru the bulkhead, if its been bent its usually off to the side which ends up chafing the cable eventually
  10. J-dog G60 New Member
    Ok mate thanks I’ll check that out ,hopefully that solves it
  11. J-dog G60 New Member
    Hi sorry for late response, think I’ve sorted it ,pedal was slightly bent and vw motorsport valve in the throttle body wasn’t set up and was sticking open so I put the original one back in
