Mk2 GTi Syncro Build - Operation MOT
Discussion in 'Members Gallery' started by Savagesam, Jan 12, 2020.
  1. Andy947 Forum Addict
    Scotland, Aberdeen
    The tunnel isn’t wider, it can’t be, the seat rails are the same in both cars.
    I was comparing mine, I’m going to cut the tunnel off above the seat rails, section the Syncro one at the same point and weld it in. Like a cap, think this will be better than cutting the floor and messing with the seat mounting points.
  2. Savagesam
    It’s definitely not wider at the rails, but bulkhead up to the seat rails it looks wider.
    that’s what I’m planning, without the Rallye tunnel. I’ve cut above the rails and will make it fit back on
  3. Savagesam
    It’s wiring time! I need to splice T14a into the loom and then splice the plug end of the loom into the Mk2 loom. Easy, right?
    Mk4 loom, just need to finish the brown plug, now I know where it’s going. So can splice and extend.
    Then pop this lot into the loom.
    Edit*
    T14a is now friends with the CE1 loom
  4. Savagesam
    Big day today!
    Started the day with a bit of rust repair,
    Usual stuff there, nothing special.
    Removed the fuel tank filler thing, because it won’t be needed with the fuel cell that’ll be fitted.
    Then onto the fun stuff.
    Measured up a cross beam,
    Diff bracket welded up.
    Then some supports fitted and tacked into place, then fully welded.
    The diff is now mounted, I’m going to add more support and build a structure around it, a place for the battery and then a frame for the fuel cell but that’ll be done at a later date.
    Front fitted.
    Rear fitted.
    Touch down!!! i wanted to get the engine and gearbox in, prop fitted but we couldn’t find the rear engine bracket dad said he had
    One day they’ll be useable!!
    Its super slammed at the moment, the coil overs need winding right up. But it rolls around, which is nice!!
  5. waj27 Forum Member
    Will sit down later and update the first photos. i used the TT tunnel which is the same on the MK4 Golf/ all the 4mo 20vt versions, helped with the prop as it bolts back in the central location as it should also can run a 3" with no problems but a mk2 carpet wont fit due the tunnel being being higher and wider but a mk4 carpet fits fine which is what i got.
    eventually will do a syncro rear axle as mine sits with a lot of camber at the moment
  6. Savagesam
    ah okay, I didn’t think of using that tunnel. Like I say, I’m just going to wing it and build it as I go.
    I’ll either get a carpet made up or make one up myself, it can’t be that difficult?
    Oh really? Is that due to the arms you made? I saw those in the thread.
  7. waj27 Forum Member
    I suppose for me i had it there already so made it work, i also did try to raise the existing a bit.. from memory its only like the rear ish section that ends up being close and touching the prop.
    Prob few places that can do it i guess the time to make one would be the pinch. paid £20 for the Mk4 carpet.
    i wanted some camber to try and tuck the wheels in as the rear axle setup is a lot wider than mk2 but eventually will revert to a syncro just means new drive shafts, possibly shorten the prop, but made sure that the original mounting points were left untouched.
  8. Savagesam
    Yeah I looked at bolting a TT on but it would have been too much work to keep it as OEM as possible. Then this lot came up, which was nice.
    I’ll have a look into it, might be worth a go.
  9. Savagesam
    Well we are back to wiring, sadly!
    Thought I’d start cleaning up my engine loom.
    The start!
    Then new plugs and wiring C77CDB97-A214-4FF9-8C14-BDC79DAB3919.jpeg C0D6A3A9-6070-4B5E-BFBA-2453E0C967E9.jpeg
    And we are done!
  10. rubjonny
  11. Savagesam
    Yeah I know but that’s £50, that I don’t really want to spend. I replaced most of it anyway as it was all broken. I’ll just keep replacing it for free until it’s all gone [:D]
    it’ll keep my busy, at least that’s what I’ll tell myself.
  12. Savagesam
    Well not a massive day today, but having my daughter around makes it a little harder to focus.
    We took the transfer box off the gearbox and found this. So I’ll have to weld that back on. Being cast, that’ll be fun! Lots of heat required!!
    But managed to get the gearbox and transfer box on, after a lot of grinding, we managed to make it fit.
    One crushed finger Later and she’s in!
    It’s tight down there!!
    Then we ran into a problem.
    DB83A8D8-B7E2-4C99-8F8C-E6ECF7AC14E4.jpeg C8EFF9B8-788B-49BA-A112-F0FA34D2ECC4.jpeg
    my rubber joint seems to be 10mm bigger across the holes, but part number marries up with a mates and his is 90mm. So I assume mine is just knackered.
    That didn’t stop me though.
    More cut for clearance.
    Then start of the bracket.
    Got the drum plates off and a disc on, now to find some carriers, as I assume they are NLA. 1532935A-2074-449A-83C7-D8B10CB53A63.jpeg
    and this is where she’ll lay, for now. The most it’ll look like a car for a long time.
    erreesse and cupracraig like this.
  13. rubjonny
    syncro carriers are 191615425A and 426, TRW part number BDA228 BDA229. showing NLA everywhere so its ebay.de for you!
    'syncro brems hinten'
    https://www.ebay.de/itm/264690670905
  14. Savagesam
    I found the part numbers on Etka but couldn’t see if they are NLA so thanks for confirming.
    This is going to be ‘fun’ :(
    I’ll get making!!
  15. cupracraig
    South West
    Great progress! well done on this
  16. Savagesam
    A little more today, not a huge amount.
    Prop is now in, and running night and straight.
    First job, start a downpipe so tunnel back in, at desired height, although this is my only picture.
    I used some steel rod to just hold it up for the mean time, I need to order some sheet metal to create a butt strap.
    then onto the DP. there’s not much room!!
    It’s tight, this is just rough mock up so far. So don’t criticise my cuts and tacking, I’ll cut it all nicely and properly weld it up when the time comes.
    Tight! But nothing touches.
    Top view.
    and here is the rough shape. I’ll obviously cut it properly and weld it up. But I know it will fit now. So that’s good.
    Then onto my mock up fuel cell, one I was planning on buying is a tad too big. So will have to find another, or get one made.
    then started with a boot floor structure.
    but I didn’t get too far with it. I packed up shortly after that.
    Steffen likes this.
  17. Savagesam
    And a big thank you to Eddie for my roller wheels, it’s much easier to push around on wheels that actually fit!
  18. rubjonny
    the other thing about the syncro/mk3/corrado tunnel is the opening is a bit wider to the engine bay so it gives you that bit more space for your downpipe, something to bear in mind if it gets a little too tight. is a bit of a bashed in section right where the downpipe needs to go, heres corrado:
    vs mk2:
  19. Savagesam
    Yeah, I’ve got a bit of wiggle room and I’ve got a bit of metal work to do, it’s fine. We’ve got space! If not, we’ll make space [:D]
  20. rubjonny
    nothing a large hammer couldnt fix for you ;)
