Mk2 GTi Syncro Build - Operation MOT
Discussion in 'Members Gallery' started by Savagesam, Jan 12, 2020.
  1. Savagesam
    Well it’s getting better, I bought some new tungsten and that helped, different gas too. Now I need more Ali and to actually clean it because I didn’t clean the previous stuff
    erreesse, afbiker02 and dodgy like this.
  2. Savagesam
    Well.. a few tweaks, a new mask and some more metal..
    We are making real progress
  3. caddyboet
    Durham
    Im glad I’m not the only one! I went through an entire bottle of gas and my welds are still no better than the day I first bought my machine. So many variables that I struggle to identify where I’m going wrong. I need to buy another bottle of gas and keep trying.
  4. Savagesam
    Haha, really!? Yeah, I’ve found writing down the settings and what I’ve done helps massively, it also means I can identify the weak point.
    It was learning how to set the machine up, then the tungsten, and then how the metal worked to start with on the weld. Lots of foot pedal then bleed it off.
  5. caddyboet
    Durham
    I don’t have a foot pedal, just a trigger on the torch which I think is half my battle. I can get decent welds on a single flat piece for metal, but when I try join two bits together it’s like starting from scratch again! Absolute mess.
    might try order a pedal and some fresh gas and have another stab at it.
  6. Savagesam
    ah okay, is the trigger not variable? Mine is, but I struggle to use it.
    I’ve not attempted to join two bits yet, as I want to get the motion dialled in
  7. Savagesam
    Not *quite* the mk2 but got to do an engine swap on my newly acquired A3 tomorrow. Unsure what to do with it tho.
  8. Savagesam
    God I’m good…
    dodgy and afbiker02 like this.
  9. afbiker02
    Bury St. Edmunds
    Doesn’t look like you’ve wasted any time Sam
  10. Savagesam
    Hit every hurdle known to man yesterday so I gave up.
    Got it back in this morning.
    Should be ready to fire in the next hour or so.
  11. Tristan
    Lots of little things different?
  12. Savagesam
    No, but things like snapped studs, bits not undoing nicely etc etc
  13. Tristan
    Oh yes. I've been that soldier.
    Reminds me of the time I removed the blown 1.8t out of my mates mk2, to replace with another.
    Missing bits, bits not fitting, wrong bits and botched bits.
  14. Savagesam
    It’s all back up and running now though. I had to basically remake most of the pointless PVC system, and I turned the key, it ran like **** wtf!? Lots of head scratching etc I’d missed a line off the inlet manifold which was causing it to have a hissy fit, popped that in and bingo. We are sweet as a nut!
  15. Savagesam
    Soooo… China is off the cards which means the Mk2 is back on.
    Fuel cell stuff.. I’ve got 3mm Ali at work, just need to take some dimensions.
    Have you seen the price of 1.8t rods!? They’re holding the engine up
    afbiker02 likes this.
  16. Tristan
    Would you not use engine mounts instead?
    Ba doom tsschhh.
    Actually, I've 1.8t Pauter rods here, I must measure the little end.
  17. Savagesam
    Har har!
    Not heard of them before! How much do you want?
  18. Tristan
  19. Savagesam
    Either size, I’ve got multiple sets of pistons, 19&20mm
    Bloody hell! And here’s me complaining at the £350 set, they’ll definitely be out of budget!
  20. Tristan
    Fair enough, because they were in a car briefly, I wouldn't be thinking of full price, but might still be a bit too much for you.
