Mk3 Crossflow heads?
Discussion in '8-valve' started by mr.brown, Dec 14, 2003.
  1. mr.brown
    mr.brown Paid Member Paid Member
    Sunny Surrey
    Noticed that yank Mk3 8v cars tend to have an intake cover over the engine and the throttle body is postioned differently - like so:
    ?[​IMG]
    Is it because they are crossflow heads?
    If x-flow heads are better, why does the US 2.0 8v have the same quoted bhp as Euro, i.e. 115
    Edited by: mr.brown
  2. 800gallons Forum Member
    because manufactorys look for economy not power, at the end of the days its still just an 8v, but with alot more potential
  3. urgti Forum Member
    United States
    All 2.0 8vs in the US cars from 93 on up are crossflows.
    The MK3 here only came with the 2.0 8v, TDI or VR.
    That pic would be an ABA coded lump.
    Jasin
  4. del_trotter Forum Member
    looks like a 2L version of mine
  5. badger5
    nr Glos
    New Beetles have these
  6. prof Forum Addict
    Suffragette City
    and some mk4 golfs the ones with a 2.0 badge
  7. Rahul Forum Junkie
    my bottom end used to have a cross flow head like the one shown!
  8. prof Forum Addict
    Suffragette City
    why didn't you use it rags?
    and does it still use the dizzy in the block?
  9. Jettin' Forum Member
    UK, North West
    US spec cars have allways been below the European cars in power due to emissions regs. The US spec 1.8 16v when it came out was still only about 125bhp compared to the 139bhp of the europe cars and this was considered close, other engines have been even worse on power compared to europe engines. By going crossflow in the US they can match the power of European cars with the quite harsh emissions regs in the US.
    They also like to keep the power the same between engines so they can use the same gearbox. This is the reason the original 1.6 GTI engine had 110bhp while it only went up to 112bhp with the 1.8. They focused on increasing the mid-range torque rather than big bhp in order to keep the same box.
    Edit: I should check what I write ocasionally
    Edited by: Jettin'
  10. Rahul Forum Junkie
    the reason i didnt use it was the guy wanted 350 QUID for it and i have a ported and polished gas flowed head anyway!
    the old distributor was used with a similar ring to the ones TSR sell......
  11. prof Forum Addict
    Suffragette City
    makes sense then
  12. urgti Forum Member
    United States
    The US cars are also more tuned with torque in mind as opposed to HP. With the crossflow you get the long runners on the intake for that.
    Actually the main reason for the US crossflow was for crash puruposes. Dont ask me to explain it though.
    Jasin
  13. jc.. Forum Member
    Virgin Islands
    Give us a clue at least...
  14. jake Forum Member
    Saint Kitts
    I'd hear this also, my best guess is that when you get punted the engine has further to travel before it deforms the bulkhead (and in turn, you), the old u-turn engines have more stuff at the back of the block.
  15. jake Forum Member
    Saint Kitts
    though looking at it it doesnt seem like a huge improvement..... must have got the wrong end of the stick again. :p
