Mk3 gti 8v intermittent starting issues
Discussion in 'Mk3' started by Whiffers, Feb 14, 2020.
  1. Whiffers New Member
    My gti randomly wont start. Wait 5 minutes then it will start then may cut out while driving then starts again.
    Anyway I took the fuel pipe off at the rail and had fuel under pressure squirt out.
    Turned the ignition on, no fuel from pipe, cranked engine, again no fuel.
    Waited a couple of minutes tried again then had a squirt of fuel with the ignition on then cranked it and had lots of fuel. Reconnected the pipe, engine starts.
    Now it's not starting again. Prior to this I thought the pump was sounding noisier than usual.
    I'm presuming the fuel pump is at fault here but is there anything else it could be?
    Should note, when this fault first happened a few weeks back I changed the coil and crank sensor as a precaution as it's my mrs car)
  2. clarky1961
    clarky1961 Paid Member Paid Member
    i live in north east england gateshead
    crankshaft sensor change that bud
  3. Tristan
    Fuel pump relay?
  4. clarky1961
    yip these to Fuel pump relay?
  5. Gti til I die New Member
    Any luck fixing this mate? Summat similar happens with mine
    Hektickvan likes this.
  6. pigbladder Forum Addict
    cambridge , uk
    fuel pump relay kinda does that ...otherwise it would keep spraying
  7. Hektickvan New Member
    Hey I'm a new member,
    My van did this but I had to wait 30-45mins for it to start,
    Also I fitted a new starter motor and as I attempted to start car turn ignition off starter motor would continue to smoke with no noise maybe the relay as well.
    Just fitted new 97gti8v motor to the van seems to run well now and I haven't changed the relays,let me know when you find the problem SOI can keep an eye on it with my car...
  8. Hektickvan New Member
    Thanks
  9. Whiffers New Member
    Hello,
    It ended up being the ecu relay. Apparently it's a common fault with them. Ordered a new one from heritage and has been fine since.
  10. Whiffers New Member
    Hello,
    A
