MURRAY HOSE CLAMPS Superior in every way to other hose clamps. Primarily for use on turbo hoses to prevent hoses blowing off, the Constant Tension Murray clamps compensate for the thermal cycling and compression set of the hose. Rolled edges to prevent damage to hoses. *Price per clamp plus Vat Constant Tension 28-38mm 3.99 30-41mm 3.93 35-48mm 4.09 40-54mm 4.10 41-60mm 4.11 46-67mm 4.11 50-73mm 4.32 57-79mm 4.38 64-86mm 4.63 70-92mm 4.50 76-98mm 4.80 83-105mm 5.10 89-111mm 5.27 95-118mm 5.13 108-130mm 5.49 121-143mm 5.97 146-168mm 5.97 159-181mm 6.09 184-206mm 6.38 Dual beaded clamps for air and also water use, produce an exceptioanlly high sealing pressure at the internal bead. Sealing pressures over standard worm gears of over 50% have been seen in testing. Rolled edges to prevent damage to hoses. *Price per clamp plus Vat Dual Bead 15.9-34.9mm 2.42 17.5-41.4mm 2.42 23.8-47.6mm 2.48 30.2-54.0mm 2.47 36.5-60.3mm 2.48 42.9-66.7mm 2.49 49.2-73.0mm 2.52 55.6-79.4mm 3.06 68.3-92.1mm 2.66 100.0-123.8mm 2.88 138.1-161.9mm 4.01 Custom quotes available depending on how many clamps are purchased! PM us!
