Oil pump will not pump oil
Discussion in 'Mk1' started by 0337, Jun 13, 2019.
  1. 0337 Paid Member Paid Member
    Ok tried to sort out the oil pressure light on dash but not having any joy as all the wires around the engine bay (sensor wires have all been cut and replaced sometime ago) need help on this plz. Is there a way i can post pics on?
    8 or 16v?
  3. 0337 Paid Member Paid Member
    8v on 1991
  4. HPR
    HPR Administrator Admin
    To post a picture : Click blue button `` Upload a File`` select a picture you want to upload … double click on it and it loads up, now select`` full image`` and click Post reply ( or load first more pictures/ files)
  5. Tristan
    I have one of those, I can check mine after work.
    chase any replaced wire sections back till you find the original wire colours. the switch on the head should be blue or brown 0.25-0.3 bar with a blue/black wire. the switch on the filter housing should be a white 1.8 bar with yellow wire. But only go by the wire colours if genuine VW, if pattern need to check the pressure ratings stamped on the side/back. The smaller white sensor on the filter housing is the oil temp sensor for MFA which should have a green/black wire.
  7. 0337 Paid Member Paid Member
    The pressure switch on the head has got a yellow wire & the filter housing one, following it back is Green/ black wire (will have to check properly as am at work at moment) also will try to load up some pictures of wiring.
  8. 0337 Paid Member Paid Member
    20190618_183316.jpg 20190618_183316.jpg 20190618_183345.jpg 20190618_183423.jpg
  9. 0337 Paid Member Paid Member
    Here are some pics. Hope you guys can direct me in the right place.
  10. 0337 Paid Member Paid Member
    Just noticed the fuel gauge is also not working anymore.
  11. Tristan
    My 91 8v mk2 Digifant, with everything working properly..
    Sensor on Side of head over gearbox, wire is blue with black stripe.
    The bigger sensor, iirc that's the pressure one, on the filter housing, has a yellow wire.
    The smaller sensor on the housing, oil Temp iirc, green wire with black stripe.
  12. Tristan
    Easy to remove the sender from the tank to check.
    You might have earthing issues near the fusebox too.
  13. 0337 Paid Member Paid Member
    Everything was fine until I striped the engine to do oil rings, since then its been a nightmare. I didn't touch anything in side the car only the engine bay.
  14. rubjonny
    ok you need to chase all those wires back till you find the original VW colours.
    switch on the side of the head should have a blue/black wire, big switch on filter housing should be yellow. small sensor on sensor housing should be green/black. There shouldn't be a wire from the harness to the distributor, that is a suppression earth to cap. you will have 2 brown/white earth wires to the head, once from fusebox and the other from the ecu.
    Other issue I can see, a 91 GTI would have a digifant engine but you have a carb/kjet vacuum advance unit on the distributor. Is this a factory installed engine or a swap?
  15. 0337 Paid Member Paid Member
    Hi rubjonny, this is how I bought the car in March this year, i couldn't tell you at the moment will have to check log book and engine if number match.
  16. rubjonny
    take a zoomed out piccy of the whole engine bay :)
  17. 0337 Paid Member Paid Member
  18. 0337 Paid Member Paid Member
  19. 0337 Paid Member Paid Member
    Ok this is the loom i have followed up just before the wires where joint on.
  20. 0337 Paid Member Paid Member
    Ok i ve followed the wire as you mentiined and the green & black wire goes from dash plug to small sensor on housing, is this right?
