hi pal cheers ive got auto data , and think ive roughly sorted how to wire it up ,,had some forium advise ,,,so fingers crossed ,,, as ill be bisy for a few week on other things ,so following week ill try to wire it up and hope we have spark and feul lol
ive still got it ,,i resprayed it and added a few extras and its been sat in the garage for over a year i reckon ,,due to other things need sorting pic of the car as added some better deep dish wheels and upratted the front suspension more stress this wireing looks a nightmare fuse box removed
first i found some nice burnt wires ekkk then added the vr6 engine loom ,,dam wireing lol just short of a couple of engine relays dash had to be removed to due to dam wireing location and replace those burnt wires ive a few spares wires and unsure if there needed and a couple which have been snipped ,heres the pictures if anyone can help ,it would be a mirrical if this will ever run , and this relay is a number 53 which is joind into the vr6 loom ,but if i remove it and plug it into the location on the fusebox ,how do the wires couple up via pins,or will it be ok left were it is ,/// shown here :bh
still stuck regards the wireing so ,did a bit more bit of time to do a bit more this after had to re modify the bottom engine brace as i didnt realise the raditor dosent sit straight and a bit off the engine mount just to clear the raditor cores then bit of cut and chop raditors in , should be just enoegh room for a slim type cooling fan then thought best sort a hole out for the dipstick lol as u can see not too mutch room at the bottom ,but it will do the job saves fitting daft small radiators which wont cool right as this one will ,,
Brilliant job - I thought a 1.8t was tight in a Polo. Love the engine mount brackets and the front cross member. Re. the electrics - where are you based, anywhere South? All the best.
haha nice its not mine ,just a bit offun for a mate really ,,,i never have problems getting ought to fit ,its the dam wireing whats my let down ,,,,im nr donny in south yorkshire pal ,,
small update managed to get the fluid clutch converted from cable to fluid done bit of scrappy hunting for a pedal and modifyed it along with a bit of cutting job done getting there....but carnt get a spark or feul as yet grrr got some biggar brakes to add too
