My wife's 57 plate (07/11/2007) Polo SE 80 auto has a very wet rear passenger side foot well. I only noticed it when i spotted some mold on the loose mat & lifted it up to notice the carpet was saturated???? Any idea's? Boot is dry as is both front wells & the rear driverside one. I'm thinking the door area but it's hard to tell with all that plastic crap over the sill inside & the underneath of the car has that huge metal shield blocking off direct sight of the floor. Mike
Has the car got aircon??? I know a few VAG cars in the past have suffered from the drain pipe from the A/c blocking and ending up coming into the cabin ???? might not be right but worth looking at
Have you had the rear door glass replaced not sure if polos have the metal membrane behind the door panel but could be worth checking to see if it's letting water through
nope nothing replaced on car, can't notice wet along sill though hard to tell with carpet & due to shape of car i think the front of the rear door & the rear of the front door each half cover the footwell.
there's some plugs on the underside of the shell, one of these could be split and letting road water in under the soundproof matting Can't think of much else
thats one of my guesses or a leaky door, might have to pop it to a friends business to take a look as we have wet weather & the mk1 is in my own garage. was hoping for a commen fault or something lol. thanks all mike
Right Mike, heres one for you any signs of damp in the boot area, what I have seen more than once is one of the rear lights have been pulled out to replace a bulb. The person undos the wing nut holding on and 'drags' the light off instead of lifting it up and out the dragging movment bends the metal where the retainer sits, not allowing the light unit & seal to sit flush with the body letting in water which finds it way into the foot wells often let us know how it works out, other than that remove the carpet (which I advise you to do anyway) and water test to find the location
lifted up the tyre cover & looks bone dry. phoning the garage tomorrow to see if they have a slot to check it.
I did notice that when i open the door i get a splash of water onto the floor like it's staying on one of the sills?
