hello its been some time that i have worked on these engines i have bought a partially dismantled block and am about to reassemble it but i cant recall the procedure for installing the bearing caps number 1 - located at timing end. number 5 - located at clutch end looking at the pictures do the figures 1 to 5 sit as shown using the oil pump fixing on the block as a reference point or do the caps have to be rotated 180 degrees and the figures would be on the bottom?
First pug motor I built, years ago, wouldn't turn. French label theirs from the flywheel. Lesson....., assume nothing, LOL Jon
many thanks its just as i thought and i have it correct- but had a nagging doubt in my head i was afraid to pull it all together only to find i had something wrong thanks for the picture 2swe.
