RS turbo recaros into a Mk2
Discussion in 'Mk2' started by philkimber, Dec 8, 2016.
  1. philkimber Paid Member Paid Member
    A question thats been asked a thousand times no doubt...
    however, after searching I'm struggling to find a 'how to' or some form of guide on a way of adapting the existing Mk2 subframe to mate it up the RS turbo seats. Ford seats require the Mk2 frame to be narrowed but keeping the foot print of the Mk2 seat for the floor runners. I have a welder who says he will do the work for me, but as I cant get the car to him (and he cant get to me) I need to go to him with some instruction or basic mock up. I've already cut the seat pan from the bases.
    The options are
    1. to put two runners into the inside of the existing Mk2 frame. I think this will look ***** as the existing frame will be visible pertruding from the seat base.
    2. cut up the existing frame, create a new one using the feet and slide adjustment. Fear is that the seat wont be level and could lean too far forward/backward.
    Any advice/tips welcome.
    Cheers
  2. dragonfly
    dragonfly Paid Member Paid Member
    Birmingham
  3. philkimber Paid Member Paid Member
    lovely, thanks :thumbup:
  4. sprout99
    sprout99 Paid Member Paid Member
    Durham
    Be careful you don't end up adding too much height by fabricating brackets.
    I searched for months for the right solution to this problem
    Ended up with a pair of genuine recaros
    That needed inserts re trimming.
    Mk3 golf is cheapest and easier option with minimal fabrication
  5. rubjonny
    Some Ford seats have an extra frame welded to the bottom, if so the way I would do it is chop all that off giving you a flat base same as any aftermarket or mk1/2 recaro seat. then you can weld in 6 captive nuts or fit rivnuts where the holes are and it will take a standard recaro subframe (or one you make yourself)
  6. philkimber Paid Member Paid Member
    I was told they are from a Fiesta RS turbo, they have a pretty flat base with 6 holes where the old ford subframe bolted to it. I'm going to go up the car this weekend with a MK2 subframe and recaro seat and see how they lie. I've a feeling I'll end up with recaro bases from ebay.de
    I'll add some photos over the weekend
  7. philkimber Paid Member Paid Member
    My fear is making them too high...I've a trimmer local to me and would like to get them over to them in the new year.
  8. rubjonny
    ok cool, its basically identical to a mk2 recaro except it has extendy leg bolster so a mk2 subframe will bolt right on. just a case of how tall you are if the mk2 are the right height for ya. oh and if electric need to jump them with 12v to raise and lower dont forget :p
  9. sprout99
    Durham
    https://goo.gl/photos/2fKhibUevPkjgnKKA
    These are mine.
    Even wired up the electric height adjust.
    Seats cost me 800 and retrimming the centres to match rears cost me just short of 200 that included the leather.
    They were something I wanted to finish car off.
    philkimber and MUSHY 16V like this.
  10. sprout99
    Durham
    MUSHY 16V likes this.
  11. MUSHY 16V
    aberdeen
    They look nice bud and quite a good price too
  12. GAD
    gad Forum Member
    I bought my Mk2 recaro seat bases from southside audio - not sure if they still do them, worth a try though
    Dav.
  13. philkimber Paid Member Paid Member
    Thanks all - I think they really compliment and finish off a mk2 interior, mine will be trimmed in rainbow fabric once they have been fitted and I'm happy with them!
  14. philkimber Paid Member Paid Member
    These are the bases of my seats, yesterday I tried mocking up the seats into the some Mk2 frames with the pan cut off (i.e just the tubular section) and they work if they sit within the outer edge of the frame and are about the right height. on closer inspection of the seat, these seem to have an extra frame on them, below the tension lines on the bottom of the seat. If this was cut off, theyd fit a lot better. Is this what I need to do?
    [​IMG]Untitled by Phil Kimber, on Flickr
    oh, on the one I'm using for trial fitting I've already taken the legs off attached by the 4 visible nuts
  15. rubjonny
    yeah thats the ford type with the extra frame welded onto the bases. so you can either cut that off and weld 6 nuts or drop in some rivnuts, or make your subframes attach to the bottom of the extra frame.
    if you left those extra bits on trouble is that would mean your subframes will have to be shorter than normal to stop the seats sitting too high
    philkimber likes this.
  16. philkimber Paid Member Paid Member
    Thanks rubjonny - think the easiest thing to do is cut off the extra framing and bolt the existing frames to the seats. Headache over!
  17. philkimber Paid Member Paid Member
    OK - update. I chopped down the ford frames right back to the seat (where the clips attach to it) - chopped down a set of mk2 seat pans and had a mate weld some brackets on to the Mk2 subframes and he welded some bolts onto the ford seats. The seats then bolted to the subframes. Cleaned up the subframes and gave them a coat of satin black, edd china style. Next delivery will be the fabric from heritage and then off to the trimmer!
