Sequential 02A build
Discussion in 'Transmission' started by Brian.G, Jan 5, 2011.
  1. jimk04 Forum Member
    Lost me!
    I'm struggling to build a 6 speed 02S up using off the shelf parts!
  2. Brian.G
    Brian.G Forum Member
    West of Ireland
    Dan, I know what your saying about the clusters/baulks all being in the one case, but, for me, its important for it to be all Vw. Its pretty much as simple as that, although tougher.
    As for ratios, its either the 02a or the 020, the 2y is limited also with fds, the aug, better, but its an 020, which as you know has its own problems after a certain point.
    I have an lsd here also for an 02a.
    I found the (cant remember what codes) 02as to be ok on the last golf where I ran a couple of different engines in.
  3. danster Forum Addict
    I totally understand that point if it must be VW and you already have the diff.
    Carry on. :thumbup:
  4. Brian.G
    West of Ireland
    Any other manufacturers part under the bonnet is sacrilege in my eyes. Its ok if I make other bits myself though:thumbup::lol:
  5. RobT
    RobT Forum Junkie
    Cheshire
    Might be tricky to stop the oil coming out.....
  6. Brian.G
    West of Ireland
    Not if its all machined/sealed nice:thumbup: Plus, its spray oil, not constant submersion. Theres grades for different conditions, I cant think what they are now though.
    Ill have to remember them all though when ordering the steppers/actuators. Id like to fit the reverse actuator inside the box for compactness/out of harms way.
    Thats the plan anyway:lol:
  7. RobT
    RobT Forum Junkie
    Cheshire
    This is proper bonkers - but good luck to you
    I have 2 unrelated thoughts:
    The actuation of these boxes can be done with 2 servos - fore/aft on the lever, and side to side. l am surprised no one has yet done this with push bottom control on the wheel
    I don't really see the point of a drum selector unless you are going to use dog gears
  8. Brian.G
    West of Ireland
    Im surprised too actually.
    As for the actuation, you still have all the levers inside, and all that slop to deal with when driving the forks from the top of the tower where cables go on box.
    Plus, the code for controllers would be more complex Id imagine with every change, and would take longer(minor issue as the syncros still need time, but still), and, Im far far better at making things than I am writing code:lol:
  9. RobT
    RobT Forum Junkie
    Cheshire
    If you use a mk4-type 6 speed shift tower, which is actually a mag casting, and rose joint-ended cables, and bronze bush the selector forks, it's surprising how little slop there is. I have this on my dog box with a sequential shifter and it's as quick as your hand can move - you would certainly beat the synchros if it had them.
  10. Brian.G
    West of Ireland
    You still have to take your hand off the wheel to change gear though right?
    Id like to get away from that and use paddles on the wheel. I know the shifter mech you have, and it is nice, I looked at its design a lot. Its a very nice price too though, something I could not commit to:thumbup:
    However, going this route is more or less cost free bar minimal materials, and a few electronic bits, which, I have a vast collection of from the past 15 or so yrs.
    Its something to think about in the evenings too, I dont play golf:thumbup::lol:
    So theres two setups that are used, one, uses just a drum, the forks slide on this drum, and are also controlled by the corkscrew groove in it, like the one below,
    And the other, as seen in the F1 box, it uses another pillar/shaft to mount the forks, and the drum to control them via the dowel pins.
    Like so
    The first is compact, just one shaft for all. But from looking at it, it has its cons too.
    Given that all the forks are mounted on it, it carries the rotational drag of all them when turning, even though just one is moving. Id Imagine when it wears(If the fork bush did not) Then the whole thing would need replacing. This would not be the case with the other setup, where the pillar shaft could just be replaced on its own.
    It would also need to be of uniform diameter, in order for the forks to slide on it. And cannot be lightened like a stand-alone drum could be.
    Im thinking now, to get around the fact that 5th is on the other shaft, and away from my proposed pillar position a bit, is to mount the 5th gear fork on the end of the drum shaft, and not the pillar where the rest of them are mounted. A dowel pin arm could be brought down from the fork, and connect with its groove on the end of the drum.
    Hmmmm
    BG
  11. RobT
    RobT Forum Junkie
    Cheshire
    There's no question, a proper drum setup like the second one you show is the way to go ultimately, my seqshift solution works well but it's not as good as a this.
    I have been having discussions with a couple of firms to actuate my seqshift system with pneumatics - this will then be with buttons on the wheel
    Have you seen the seq box from tractive? Beautiful design with a drum like your second pic.
  12. danster Forum Addict
    Have you got a link for that?
  13. Brian.G
    West of Ireland
    Yup, spotted that, its tidy:thumbup:
  14. m1keh Forum Member
  15. RobT
    RobT Forum Junkie
    Cheshire
    Tractive sd90
  16. RobT
    RobT Forum Junkie
    Cheshire
    I have a brochure here with some cracking pics in - need a scanner!
  17. danster Forum Addict
    Cheers folks, I thought there may have been a vid of it in action. Internal design / cutaway sort of thing. I did look at the site and saw the box but thought there may have been more.
    Sorry for off topic Brian but thought it may have given folks an idea of how the drum and selector forks work.
  18. m1keh Forum Member
  19. Brian.G
    West of Ireland
    No probs Danny, post away, thats what its all about too!
    I like the approach they take with constructing a box, multi sided, almost cylindrical(cylinders have the best stiffness)
    Its almost like lego!
    Heres the basic design, all there boxes follow these construction lines, fwd, or rwd.
    Bet to it by Mkeh!
  20. m1keh Forum Member
    Silly thing is stuff like this is oe spec on motorbikes. If only car designers had followed suit.
