Southbend Clutch
Discussion in 'Transmission' started by boostedgolf, Jun 29, 2020.
  1. boostedgolf Forum Member
    malta
    Hi all, been a while away from this forum....
    So a few years back i did a 20vt swap in my mk3 which i never went all the way of sorting it out.
    I have installed a southbend stage 3 endurance up-rated clutch which never felt good... the pedal is super stiff, clutch never really disengages completely, i need to let revs drop below 3k rpm to be able to shift gears. Also if the car is stationary, engaged in 1st gear, if i rev it up with the clutch fully depressed to the firewall the car will still take off.
    Any idea/ experince on this matter before i bin a 400 eur clutch?
    I bought from JBS auotodesign which where of no help & when contacted southbend never gave any reasonable help neither.
    Car is to be used as a fast road/ track day car.
    thanks.
  2. Savagesam
    If you buy another, don’t bin it, some muppet on Facebook will buy it!
  3. Tristan
    I wonder is the clutch fork bent/bending...
  4. boostedgolf Forum Member
    malta
    But would it justify the heavy pedal? i read around that they feel oem or even softer... friends have a clutch master installed and their pedal is feather light..
