Steering column support bolts
Discussion in 'Styling, Trim and Bodywork' started by J-dog G60, Mar 4, 2022.
  1. J-dog G60 New Member
    Hi I’ve noticed that one of the steering column support bolt was lose ,so went to tighten it and it fell out and there is no thread to hold it in , is there meant to be captive nuts ?if so is there anyway of getting to it without taking the clocks and possibly dash out ?
    They're usually security screws that the head snaps off of, once they're tightened up.
    But should have a standard m8 thread. 16464336236522791927471047756937.jpg 16464336593717846345800278119119.jpg
  3. J-dog G60 New Member
    Hi mate not this bit the bracket above that has 4 13mm bolts on it
  4. Tristan
  5. J-dog G60 New Member
    It’s the bracket that’s in your pics ,I need to know how it fix’s to the body of the car
  6. PhilRyder
    A quite fortuitous thread as I need to tighten ours up as the column has some vertical movement which I am sure is not supposed to be there. I hope our threads are OK, unlike yours. However, in answer to your question I’m pretty sure the column bolts are directly into part of the dash frame which is a welded part like this. This is lifted from the MK2 workshop manual. Part one are rubber washers which it seems are only found on a diesel.
  7. Savagesam
    The whole column bracket then bolts to the dash using 4 m8 bolts.
  8. J-dog G60 New Member
    Ok mate is there meant to be captive nuts to bolt the m8 bolts to ?if so is there any access holes on the lower ones so I can get in there to but and bolt it ?
  9. Savagesam
    Yeah they’re captive or rivnuts fitted to all 4. No access as it’s welded to the frame of the car.
    You could drill it out and fit a rivnut
  10. J-dog G60 New Member
    Ok mate that’s a good idea ,I’d probably still have to take clocks out to release the support bracket to get a rivnut in there
    Savagesam likes this.
