Sump was removed for 3 weeks refitted and just filled it to correct level and started but the oil light is now flashing at idle and engine sounds noisey. 96 agg
Ok thanks just got the oil pump out is there supposed to be a gasket or seal between it and the block as I have nothing there?.
Cheers guys new pump primed and fitted oil light is off first turn and engine sounds Great again will try out my new clutch,shift linkage and replacement gearbox (with all the teeth on the reverse idler) this weekend.
