TFSI 1.8T Oil pump conversion.
Discussion in 'FSI (inc. GTI 2.0T)' started by murph81, Apr 18, 2015.
Tags:
  1. murph81 Forum Member
    Republic of Ireland.
    Did you try the 1.8t oil filter housing?
  2. murph81 Forum Member
    Did you try the 1.8T oil pump?
  3. Skjalg hammer New Member
    did not try the 1.8t filter housing but did try the pump, it seems like it cant give enough oil to everything fast enough. so the tensioner for the camshafts didnt get enough oil, i could hear it getting bad. but it does take a long time before it does go brake, i drove around with a broken tensioner for half a year before i did do anything with it. so i dont know if it would get better with the 1.8t filter housing. you will have to make modifications to the connector for the oil pressure switch. i didnt want to do that thats also one of the reasons why i stopped turning it to that pump. the connector i have is a 2 pin one, and the 1.8t oil pressure switch is a 1 pin.
