The VAG-COM / VCDS owner directory thread.
Discussion in 'Vagcom / VCDS' started by Trev16v, Jun 19, 2011.
  1. modded a3 New Member
  2. mitlom
    mitlom Forum Member
    Ripley, Derbyshire
    I'm fairly sure that if you are fitting a new module it will need to have coding added. The easiest way to get the coding is off of the original module, however it can be generated from scratch by referring to the options sticker in the boot of the car :thumbup: Clearly you will need access to VAGCOM or VCDS in order to do this.
    Tim
  3. modded a3 New Member
  4. Stewy
    Stewy Paid Member Paid Member
    Midsomer Norton
    Full Vag-com /usb Bristol
  5. iib3327 New Member
    i have full vag com, VCDS, vag commander and mapping software in Tamworth staffordshire.
    Matt
  6. miggs2002 Forum Member
    Preston lancs
    i have a fully working VAG COM with the ebay special blue lead, it will read fault codes up to the mk4 golf platform and also clear codes as well as activate alarm chirp and auto lock/unlock (anti hijack)
    i also have the software to do auto windows (power up and down of the remote key) on the mk4, this will only work with certain CCM's i believe the immo 3 ones, i'm willing to try if you aren't sure
    i am near Chorley, Preston, PR5 postcode
  7. techy New Member
    South Yorkshire
    Full Genuine vcds/vag com Barnsley/Rotherham/wakefield but i do travel about
  8. Sean_Jaymo Forum Member
    Lincolnshire
    Full VAGCOM in South - Central Lincolnshire.
  9. BenjaminVWH Club GTI Sponsor and Supporter Trader
    Full VCDS, 2x2, Vag tacho, Vag k+can, Galletto 1260, mpps. West sussex. :thumbup:
  10. vee-dub90 New Member
    Full Vagcom/vcds and also have 2x2 lead based in Bridgend - S. Wales
  11. StuTibs New Member
    Fleet, Hampshire
    I have full genuine vagcom on a laptop. I'm based in Fleet
  12. andipandi Paid Member Paid Member
    full vagcom can 2+2 plus others in hastings
  13. Dubmeister1997 Forum Member
    Southampton
    Anyone in Southampton/New Forest area with VAGCOM that might be able to help me?
  14. JWYATT Forum Member
    South Coast
    I have full genuine Vag-com , Located around , Petersfield / Portsmouth / Southampton / Chichester area .
  15. aminder
    aminder CGTI Committee - Webmaster Staff Member Admin
    Leicester
    I have full VagCom which will support all latest cars - based in Leicester
  16. Lod_Dub Forum Member
    Spalding, Lincolnshire
    Full VAGCOM by Ross Tech
    Based near Spalding, south Lincolnshire
  17. huw169 Forum Member
    VCDS lite and ebay lead. Only tried it on MK3 golf ABF to clear faults. Located in Portsmouth...
  18. slimwadey Paid Member Paid Member
    Thatcham Berkshire.
    VCDS with Rosstech lead, can read and delete faults on early cars inc most 20v turbo
    Based in South London/Sutton/Croydon area, also work in Kent
  19. bootsie Paid Member Paid Member
    Brackley, Northants
    VAG-COM / VCDS 10.6 Full Version with "special" (don't ask) cable.
    Based in Brackley, Northants - 20 miles from Oxford/Northampton/Milton Keynes
    ragitaround likes this.
  20. ragitaround Forum Member
    ashford kent uk
    Hello people i live in ashford kent se & i would like to know if there is **** in this area with a full vag com that could help me get my steering angle sensor calibrated ?ive got a new maf on the way to me so i can sort that code out but i have esp issues which j assume are related somehow!?
    I replaced the front abs sensors but not the hub tuners which i am going to do as soon as i get more coin . I have a mk4 golf 1.8t gti 20v AUM 2003 model. If theres **** please pm me ill be most appreciative. Cheers paul
