Tubular seat rail installation
Discussion in 'Track Prep & Tech' started by A.N. Other, Aug 14, 2006.
  1. gillm
    gillm ***** User
    yeovil somerset
    sealant removed
    thinners to remove all the sticky crap
    arond 6kg removed by doing that
  2. badger5
    nr Glos
    how l.ong are your legs Gilly?
    you trial fitted your seat yet to confirm brkt positions etc.
    I'm going to have to rmeove my ibiza OE runners as the sills cracked and split on the drivers side which is a bit scarey. Plate is seriously thin and flimsy on the sill
  3. jamesa Forum Junkie
    Abz
    If it`s any help, here`s my Mk1 ... I`m ~ 5`10" with inside leg ~ 31".
    The position is actually too high, could do with being an inch or two lower.
  4. gillm
    gillm ***** User
    yeovil somerset
    yeh trial fitted it . palm of my hand touches the top of the steering wheel when sat back in the seat .
  5. altern8 Forum Junkie
    Cocos (Keeling) Islands
    how did you remove the original seat runners ?
  6. gillm
    gillm ***** User
    yeovil somerset
    angle grinder
  7. A.N. Other Banned after significant club disruption Dec 5th 2
    Spot weld cutter is the best, neatest way. Little bit of angle grinder for the front sections which are mig'd on. Finish of by removing stubs with the belt sander.
  8. badger5
    nr Glos
    my inner rail wont come off from spot weld cutter.. material is too thick... evil job. disk cutter, awaiting more disks at th emo... its' hard stuff!
  9. badger5
    nr Glos
    evil ibiza...
    got more cutting disks arrived today.. its coming out dead or alive (it or me)
  10. gillm
    gillm ***** User
    yeovil somerset
    bill get some slitting discs and flapper discs . Thats how i did mine . And i rubbed the paint back to find the spot welds and drilled them out
    Wipe with thinners usually reveals the dimples in the metalwork from the spot welds.
    Centre punch, and on with the spot weld cutter.
  12. badger5
    nr Glos
    spot weld cutter wont touch my rails. materials too thick. tried that.
    inox 1mm slitting disk got it off in 30secs.
    Any pics of the slitting discs? - sounds like a useful tool.
  14. altern8 Forum Junkie
    sounds good i need to do mine soon too if its that much easier using the slitting disk
  15. gillm
    gillm ***** User
    yeovil somerset
  16. badger5
    nr Glos
    I bought some from Buck & Hickman, Inox stainless steel 1mm cutting disks... 1/2 used just the one disk! amazed it lasted so well.
  17. micky1 Forum Member
    Bath.
    Bill,
    the clue is in the name INOX. aka stainless steel aka 1.5 times stronger than pig iron!
  18. mk1 driver Forum Junkie
    Nottingham
    Has anyone seen the new tubular seat mounting kit in the 2008 Demon-Tweeks catalogue? Page 158, 40.
    "Contains 2 x 560mm long, 25mm OD CDS tubes, 4 mounting brackets with floating M8 nuts and 4 side strengthening plates."
  19. jamesa Forum Junkie
    Abz
  20. gillm
    gillm ***** User
    yeovil somerset
    so thats 80 for 2 seats plus postage ? makes mine very cheap indeed
