Unknown wires
Discussion in 'Electrical' started by magictree, May 12, 2020.
  1. magictree
    magictree Paid Member Paid Member
    Chelmsford, Essex
    does anyone know what these wires are coming from the black plug near my heater fan plug in my picture? They continue to 2 further plugs which aren't connected to anything then the rest are just snipped off. I guess its nothing important as everything works, it just worries me a bit as they look factory.
    Looks non vag, like a previously removed alarm or sound system components.
  3. magictree
    Chelmsford, Essex
    Thats good news. there is so much unused wiring in my car, most of it is obviously aftermarket but I thought this looked factory. One day I'll get it all stripped out.
    random black and brown/clear 2 pair cables aftermarket, assume speakers. the white and black 2 pin plugs near by are original speaker plugs, black goes to dash speaker, white is where door speaker wiring plugs in. cut off wires with cable tie is original vw stereo speaker plug chopped off as per usual. single black/red wire with clear spade is for the glovebox light
  5. magictree
    Chelmsford, Essex
    Blimey, is there anything vw you don't know?
    well when you've worked on as many wiring looms as I have these things become 2nd nature :lol:
  7. Bomber604
    Bomber604 Forum Member
    Shrewsbury
    Would the glovebox light cable come from the fusebox or ignition switch area? I have a long single black & red coming from the ignition switch with a single pin factory connector halfway along it. Any idea?
  8. Toyotec
    When I am building my projects, I use A2 Resource, my A2 Bentley as well as the Golf MK2/Cabrio Chilton to work seamlessly on MK1 or MK2 electrics.
    If you need a copy of any relevant area, I can share. You will need to be proficient in reading VW current flow.
    I could not build any of my cars without those resources.
  9. rubjonny
    glovebox light comes from the fusebox, the wire you have doesn't sound original. pics?
  10. Bomber604
    Shrewsbury
    My mistake, it's brown & red. Quite a thin wire with a square connector half way along it. Comes out the back of the ignition barrel.
  11. rubjonny
    ah thats the key-in-ignition live for the radio. the plug is where the ignition loom side plugs into the dash side :)
    Bomber604 likes this.
  12. Bomber604
    Shrewsbury
    Thanks mate, that's getting binned then!
