Afternoon all.. My mk2 golf used to have front and rear washer jets but the rear was deleted by previous owner.. I’ve now relocated the reservoir and lengthened the wiring using the original plug.. but now the washer motor only works when I push the stalk away (rear) and not toward (front) I’ve tried reversing the wires but it’s the same result.. it worked fine before I swapped to an aftermarket reservoir and pump can anyone help
so the washer previously used to spray the screen when you pulled the stalk back, and now even with wires switched the pump only works when pushed forward? when you switched wires the opposite washer jet works though right ?
Thanks for the reply, I only have fronts.. the new washer is a single outlet (the rear has always been redundant, even on the original bottle .. hope this helps
oh I see so you dont want the rear washer to work, I thought you were trying to add the rear washer back in do the front wipers come on as well when the jet comes on, or do you only get the wipers when you pull back on stalk just no washer
The wipers don’t either! There is no voltage (not even residual or indication of a short) when I put the multimeter in the pump plug either.. what I neglected to say is the stalk is aftermarket from heritage it’s currently in for MOT this morning so when it’s home I’ll strip the column and check my connectors, however everything else works including mfa Do you know what plugs are linked to washers on the back of the fuse board? It might be worth me checking there too
if the wipers dont go when you try to wash the screen but they work normally when selected this suggests to me stalk or wiring to it, have a look at the fusebox FAQ you're lookign at pins T and L on the stalk to plug H1 on fusebox: https://clubgti.com/forums/index.php?threads/fusebox-faq.219775/#post-1945617
