whats wrong with my vr6 - place your bets
Discussion in 'Engines' started by AndrewF, Oct 23, 2003.
  1. AndrewF Forum Addict
    Milton Keynes
    car sometimes judders at low speeds (usually when in high gear). also, it dad have a strng smell of fuel coming from the boot area, but that has dissapeared. and now its idling funny when you start it.
    i know i really need a vag-com check, but can't afford it (and don't wanna pay vw 50 squids for them to plug a computer in my car). i have a limited warranty on the car, but don't wanna claim on it until i know what is exactly wrong (don't wanna replace the wrong part).
    here are the possibles (suggested so far)...
    -coilpack
    -fuel pump (believe theres 2 pumps - a lifter and a main?)
    -cam sensor
    here's the test i've done...
    -sprayed water on the coilpack at night, no sparks.
    -opened the hatch in the boot to look for leakin fuel, didn't remove anything (wasn't sure how to depressurise the fuel lines), but it was very dry down there.
    whats do people think? or does anyone live in berks and have vag-com that i can borrow?
  2. veedubnutz Forum Junkie
    Worcester UK
    Just go through all the electrics, check all plugs/leads/ dizzy cap and rotor arm. Bound to be electrical!
  3. vrbanana Forum Junkie
    Sunny Sheffield
    still got my cash on the coil pack.
    Did you ask Phatty about his coil pack???????
  4. PhatVR6 Forum Junkie
    Air flow meter connector. clean it with WD40
  5. AndrewF Forum Addict
    Milton Keynes
    where's it located?
  6. evozippy Forum Member
    Try the 48pin plug on the side of the head, open and close it a couple of times, as wet degridation can cause poor connections!
    Also look at the dissi cap and rotor arm for carbon build up and clean them.
    Could need new spark plugs.
  7. AndrewF Forum Addict
    Milton Keynes
    it' dbe safe to spray wd40 on this wouldn't it (helps dissapate water)?
    Edited by: acf8181
  8. evozippy Forum Member
    Yeah it would help. See if there is blue stuff on the pins, if so try and clean it off.
  9. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Its doesnt have a dizzy cap or rotor arm.
    In my vast vw experiance you will see if the coilpack is fault by looking for a crack in the face of it (looks like resin). My bets on a hose on or near the throttle body.
    Have you lost any performance or done any recent mods?
  10. evozippy Forum Member
    The early vr have dissi caps, i think its 93 onwards when they changed to electronic distribution.
    Edited by: evozippy
  11. AndrewF Forum Addict
    Milton Keynes
    it is a coil pack model...it was only the first few '92 models that were dizzy.
    the coil pack does look a bit cracked actually...i'm probably gonna have to get vag-com, it think it'll be the only way to sort it!
    '1990' - didn't you find somewhere that'll do a group buy on it? (check my post in misc tech q's)
  12. PhatVR6 Forum Junkie
    If it "looks cracked" then it is, it'll be f8cked. [xx(]
  13. AndrewF Forum Addict
    Milton Keynes
    the main bit of the coil pack looks fine, its just round the edge towards the front of the car it looks a little cracked (only a little though). i'll post pics later if a i can borrow a mtaes digi cam.
    another dumb question...how to i undo the big round wiring plug from the engine, so i can sparay it with wd40? (as suggested above somewhere)
  14. evozippy Forum Member
    Twist the caseing anti-clockwise and it comes apart, clockwise to put back on.
  15. AndrewF Forum Addict
    Milton Keynes
    damn, there was fluid in it (in the engine side of the plug). thats not normal is it...was kinda yellow colour.
    i've mopped it up best i could and sprayed WD in there.
    i also managed to snap a small plastic ring that goes round the outside of a rubber ring on the outside of the plug...don't think its critical, is it?
  16. 1990
    Rochdale, Lancs
    No, it took me ages to figure out how to get mine off a nd i broke a bit of it.
    The yellow stuff sounds like engine oil & water???? Dive it a damn good clean and see how you get on.
    Where do you live?
  17. AndrewF Forum Addict
    Milton Keynes
    don't think it was oil.
    gave it a clean and sprayed it with WD40 to dissapste the water, but think i shorted out my speedo when i reconnected it.
    i live near reading, down south.
  18. evozippy Forum Member
    Shorted out your speedo [:s]
    I don't think your speedo goes through that connection plug.
  19. AndrewF Forum Addict
    Milton Keynes
    well, i wasn't sure..it was just a theory.
