will this do?
Discussion in '8-valve' started by robertGTi3, Oct 9, 2010.
  1. robertGTi3
    robertGTi3 Forum Member
    Midlands
    Took this off a 1.8 vw engine, how good is this as a baffled sump? and do they come on GTi as standa [​IMG]
  2. Funky Diver Forum Member
    Darlington, UK
    Fixed the image for you :)
    When you use [​IMG] tag you only need the actual image url.
    So in your case...
    The bit hightlighted in red :thumbup:
  3. Dave
    Sligo, Eire
    Interesting.
    Does it have a VW part number on it?
  4. robertGTi3
    Midlands
    thanks Funky Diver
  5. robertGTi3
    Midlands
    051 103 623
    PA6-GF-30<
    made in austria
  6. StuMc
    50? 20` 47 N - 06? 57` 57 E
    Never seen one before but Vagcat shows it as fitting to pretty much every 1.6/1.8 VAG engine (DX, KR, 2E, etc)
    I don`t think it would work as a baffled sump exactly since it appears to just fit around the pick-up filter.
  7. danster Forum Addict
    That is just the later style of sump baffle. Came fitted on most 1.6 and 1.8 carb and injection engines from around 1990.
