I have just removed my dizzy from my 16v KR head as fitting Ford EDIS and Megasquirt. Do VW, or anyone, make a suitable cover to go on the end of the head to replace where the dizzy would normally fit??
Well, no, I expect, but suggest you either leave the old dizzy in there, or chop the end off one to plug the hole.
well i'm liking the shim idea. Thank you Rupe. Ideally, i need a shim to block the Dizzy, and an L Shape bracket from this shim to hold the 4coil EDIS pack in place.
use abf dizzy, has single trigger window and cannot be rotated once fitted. just make up a cap to cover the dizzy arm hole and grind off the rotor arm peg
Here's a link for a 16 Valve single toothed cam trigger Wheel. http://scch-heads.com/viewpart.php?id=17 Nothing Leaves Stock also makes a dizzy cover. http://www.nothingleavesstock.com/page13/page13.html http://cgi.ebay.com/ebaymotors/16v-...rQ5fTruckQ5fPartsQ5fAccessories#ht_548wt_1585
