Dizzy cover....
Discussion in 'Throttle bodies & non-OEM ECUs' started by matt1471, Sep 2, 2007.
  1. matt1471 Forum Member
    Guildford, United Kingdom
    I have just removed my dizzy from my 16v KR head as fitting Ford EDIS and Megasquirt.
    Do VW, or anyone, make a suitable cover to go on the end of the head to replace where the dizzy would normally fit??
  2. Mike_H Forum Addict
    Well, no, I expect, but suggest you either leave the old dizzy in there, or chop the end off one to plug the hole.
  3. rupe Forum Member
    Standing next to a mountain..Devon
  4. Mike_H Forum Addict
    I sit corrected :lol:
  5. rupe Forum Member
    Another way using a shim
  6. matt1471 Forum Member
    well i'm liking the shim idea. Thank you Rupe.
    Ideally, i need a shim to block the Dizzy, and an L Shape bracket from this shim to hold the 4coil EDIS pack in place.
  7. gosy New Member
    hi
    It would be realy nice if we could get a trigger in there also
  8. rubjonny
    use abf dizzy, has single trigger window and cannot be rotated once fitted. just make up a cap to cover the dizzy arm hole and grind off the rotor arm peg
  9. frechem New Member
    SoCal
  10. drunkenalan Paid Member Paid Member
    Leicester
    what about the ABY blanking plate from an S2? is it the same??
