Will 9a run on k-jet with 288-s cams?
Discussion in '16-valve' started by sambo, May 7, 2006.
  1. sambo Paid Member Paid Member
    As above really, i have pair of newman cams 288-s to use with throttle bodies
    It might be some time before i source few bits needed so was wondering will k-jet cope with these cams?
  2. jamesa Forum Junkie
    Abz
  3. sambo Paid Member Paid Member
    Any bad drawbacks like, shi*e idle, no power till 5k revs....etc?
  4. barny Forum Member
    Lost in Glos
    Hell yes !
  5. GVK
    Yes to which post B???
    Mine runs fine on the 272s, but the Newman site says not for factory injection on those!
  6. sambo Paid Member Paid Member
    I was also told that it wouldnt run on k-jet!
  7. jamesa Forum Junkie
    Abz
    Need to warm it up for it to idle at all (at ~1100rpm) although I`ve not yet played with the throttle stop.
    The ISV and over-run cut off systems are redundant on mine and am considering ripping them out but need advice first.
    Pulls OK from low down but I`m still to run it in, not been above 5k.
    Is yours on solids lifters ?
  8. sambo Paid Member Paid Member
    Nah, unfortunately still on hydro lifters
  9. jamesa Forum Junkie
    Abz
    Are you going to fit them with K Jet then ?
  10. Golden Forum Junkie
    I'm not sure of the full specs of the 288's but I would guess they're on the limit of what K Jet will put up with on idle.
    The low engine vacuum on idle can make the airflow flap bounce giving surging/rough idle etc.
  11. GVK
  12. I V - mk1 16v Forum Member
    Queensland, Australia
    i'd be very surprised if you can get them to run on Kjet, i spoke to newman direct a while ago on the very same cams and he was of the opinion that they definately would not run properly on kjet, and would'nt want to sell them to me for kjet, he suggested max 272's and that was pushing it. Sorry proberly not what you wanted to hear.
    Were they mr brown's old ones?? I so nearly brought them too, just did'nt want to risk it on Kjet in the end.
    Anyway weren't you going bike throttle bodies and megasquirt sambo??
  13. philip walker Forum Member
    Pembrokeshire
  14. GVK
    It would probably *run* , but just not very well [:$]
    Considering mine's not been set up properly yet it runs quite well on the Newman 272s. :)
  15. GVK
    And Altern8s? :lol:
  16. GVK
    Ahh, what do you know Phillip?
    Anyone would think you're a Newman cams dealer or somesuch.. :p
  17. stephcasscar Paid Member Paid Member
    Do you want to try my 296's on KJet :lol:
  18. TrackCab16v Forum Member
    Wales
    got some 292 s , was gona fit them just to see the out come,
  19. altern8 Forum Junkie
    Cocos (Keeling) Islands
    i still got the ones from sean in my garage and i got a set of blank schrick cams too ;)
  20. philip walker Forum Member
    Pembrokeshire
    They should run with the 288`s on k-jet with the idle around 1200+.
    To get the best out of them either carbs or throttle bodies would be ideal.
