2L 8v Mk2 specs & times
Discussion in 'Engines' started by JamesB, Jun 17, 2005.
  1. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Certainly seams that way. I think you can get a slightly bigger inlet onto the standard valve seat (40.5 against 40.0mm) but its a lot of work for the gain. yr going to need to go up about 1.5 mm for a worthwhile increase. Who done the head originally ?
  2. supercharged999 Forum Member
    BBR (GTI engineering ) did the head and valve work...
    i cant do the 'LINK' to the NOS kit that i am after , but if you type in 'wizards of nos' on e-bay,there is a used kit on there with direct port injection and a progressive controller.
  3. lowandloud Forum Member
    myne has C&R 1.9 fully balanced short block 8v gti
    TSR Pack 'A' gasflowed head
    TSR 272 cam
    TSR 4 into 1 manifold with flexy joint
    Scorpion full system
    Prima power Superchip
    Cotten and green induction
    Over sized valves
    Uprated tsr gear linkage system
    Custom short shift system
    Vernier camshaft pulley
    and i got a 15.671 @ santa pod
    not bad considering that i havent had her set up yet.
  4. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Should be good then.
  5. supercharged999 Forum Member
    what a mission to get theses parts !!!
    dealer wants 63 for 8v friction disc and 72 for 16v pressure plate.
    looks like a Black Diamond job then ? or a 300 group a clutch ???[:^(]
  6. beekeeper Forum Member
    Pretty sure theres something up with mine.
    Got rebuilt tall block, big valve head (tsr), flowed manifolds, etc, etc.
    Only managed 140@5400 and 144@4800 at stealth. Got my suspicions about the cam but not going to point fingers at persons who aren't around to defend themselves anymore.
  7. supercharged999 Forum Member
    well engine finally run in:clap: :clap:
    running :
    BVH / 276 newman cam / 2L block (2 e )/ standard ported manifold /2.25 " custom exhaust / cone filter / chip (off e-bay ).
    had it flatout racing civic v-tech.
    5th gear was @6500 rpm [:^(] [:^(] and speedo was way off the 120 mph mark.
    what a differant car to drive :clap: still got 50 shot nitrous to come.
  8. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Very good... if yr still on the original gearing thats around a genuine 130mph. :thumbup:
  9. Imteyaz Forum Member
    Warwickshire
    With TSR no longer around, where else can you get hold of the blanking plate for the breather? I have seen pics of the 2E blocks with the breather on and it seems that if you take the breather off the block, you will be left with 2 holes, the other being in line with No.2 piston on the block, can this simply be plugged with a core plu or is there another trick to this?
    Also, the larger exhaust valves (35mm?), are they standard from any other vehicles in the VAG range? (just to make it easier to try and purchase the correct parts...)
  10. supercharged999 Forum Member
    had the car on DYNODYNAMICS rollers yesterday.
    143.6 HP @ 5900 (fly wheel )
    150 ftlb @ 4500
  11. L3 ONP Forum Member
    what!!!! 150ftlb @3800, thats shocking!!!:p
  12. supercharged999 Forum Member
    sorry[:$]
    edited for new spec.
  13. Hotgolf
    Smelly Cornelly
    As for clutches, I'm running a 2.1 16v on 45 webers, which with the cam timing WAY off pushed out 174bhp and 166lbs/ft on a standard 1.8l 8v second hand clutch.
    I've been running it now for a week with the timing reset and the difference in power is exceptional, and still the standard clutch is holding out.
    I know clutches fail, but are people doing 7k standing starts with them to kill them so quick??
