So my MK2 Leon 56 plate has decided that it wants to set off it's alarm at random intervals throughout the day. Lots of fun..... fuse will be pulled soon Now I have vcds and can go to central convenice and measuring block 20 and read the alarm source codes. Unforunately I did an auto scan and fault code clear before checking this so they were all zero'd. So will have to wait till after another random activation before I can find the source code. I have by deduction found that 10 is for the interior monitoring sensors. Which does not match up with the list of codes I found here http://uk-mkivs.net/forums/p/412638/2823893.aspx or here http://www.vwaudiforum.co.uk/forum/...r-solving-False-Alarms-GolfIV-TDI-SE-115-2000. Does anyone have elsa-win or similar and can find a list of codes for the MK2 Leon as i am thinking they must be different depending on the cars they relate to.... Thanks in advance of any help provided, I will update with the code which is causing my alarms when I get it.
I completely unplugged them and it still went off. A bit of digging in similar vcds label files has turned me up this lis. Which fits my 10 for interior monitoring better. I will test others next weekend. ; 0 = Drivers Door ; 1 = Passenger Door ; 2 = Rear Left Door ; 3 = Rear Right Door ; 4 = Rear Lid ; 5 = Engine Hood ; 6 = Rear Window Latch ; 7 = Trailer ; 8 = Rear Window Broken ; 9 = Ignition ; 10 = Interior Monitoring ; 11 = Inclination Sensor ; 12 = Intelligent Siren ; 13 = Central Electronics Control Module ; 14 = Door Control Module Drivers Door ; 15 = Door Control Module Passenger Door ; 16 = Door Control Module Rear Left Door ; 17 = Door Control Module Rear Right Door ; 18 = Gateway Control Module ; 19 = Power-On-Reset (POR) Alarm (after Terminal 30 Reset an unintended Alarm is possible) ; 255 = No Alarm
