AUM no response from accelerator pedal
Discussion in '1.8 & 1.8T' started by deanage1983, Dec 8, 2013.
  1. KeithMac Forum Junkie
    Kazakhstan
    First thing I'd do is drain the carb and clean the points ;).
    Toyotec, deanage1983 and Collie like this.
  2. deanage1983 Forum Member
    Manchester
    P1361
    P1364
    Is that the pedal?
  3. GVK
  4. GVK
    If it's a typo - P1631 is an accelerator pedal related code.
    http://wiki.ross-tech.com/wiki/index.php/18039/P1631
    As is P1634..
    http://wiki.ross-tech.com/wiki/index.php/18042/P1634/005684
  5. GVK
    deanage1983 likes this.
  6. deanage1983 Forum Member
    Manchester
    Yes was a typo.
    So course of action is pedal first. Then if fault remains O2 sensor ecu
    Thanks guys
  7. deanage1983 Forum Member
    Manchester
    Ok guys new pedal installed the engine management light has now gone off. But now it does the complete opposite and revs as if the pedal is pushed to the floor.
    I'm guessing this could bea wiring issue am I right the pedal is wired straight to the ecu then from there to the TB?
    Is it a case of tracing them all?
    Thanks guys
  8. deanage1983 Forum Member
    Manchester
    The epc light remains on
  9. tshirt2k
    tshirt2k Forum Junkie
    Herts
    I think you have to do a Throttle body adaption for it to work correctly
  10. deanage1983 Forum Member
    Manchester
    No sure what you mean?
    What adaption doi need to do?
    There's a mystery plug under the shuttle that isn't connected to anything near the wiper motor too (Purple inside)
  11. deanage1983 Forum Member
    Manchester
  12. MUSHY 16V
    aberdeen
    o'dear lol
    i think most of that is for the secondary air pump
    the pipe with the cloth is anyway should go into the airbox
    i think the other two pipes are vac pipes off the inlet to do with the suction pump/ carbon fillter
    but dont quote me on it
  13. Toyotec
    To aid any issues with debugging this problem, here is the wiring path from the Pedal to the ECU.
    As you can see it is a fairly direct link to the ECU, via a blue connector, that you may want to still check for continuity.
    Hope this helps :thumbup:
  14. deanage1983 Forum Member
    Manchester
    Thanks toyotec that's exactly what I needed
  15. deanage1983 Forum Member
    Manchester
  16. deanage1983 Forum Member
    Manchester
    Ok got on it today I've got Continuity from the blue plug to the pedal.
    How does the ecu plug come apart without breaking it? I need to gain access to the wires some how
  17. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    It has a slider on it like a lid. Mine also had a little cable tie that needed cutting off before I could slide it.
  18. deanage1983 Forum Member
    Manchester
    All wiring replaced and no change.
    New pedal no change.
    Do you think the ecu has died?
    From what I understand these are programmed to the clocks is this the case?
  19. MUSHY 16V
    aberdeen
    aye the ecu would need matched to the clocks ie you would need the pin of the clocks and the new ecu thats if it's 2001 or newer
    if it's a older mk4 it's easier as you dont need a immo pin for the ecu or the clocks for changing the ecu
    i'v done a bit of messing about with this so know most of the in's and out's lol of getting the skc pin from the clocks and ecu lol
    you would need some with vag-tacho vag-commandor and vcds ie vag-com
    a other option you do get places that repair ecu's
  20. deanage1983 Forum Member
    Manchester
