early/late abf inlet manifolds pics and differences
Discussion in '16-valve' started by LregG, May 18, 2009.
  1. LregG
    LregG Paid Member Paid Member
    has anyone got any pictures of abf inlet manifolds with the part number ending in bg and bh please until i post some as and when my later type turns up
    Gregg :thumbup:
    heres a late MK3 one, I have a late SEAT one in my garage if you want better pics. basically the main difference is the vac pipe at the back for the ECU, early ones didnt have that. also IIRC the shape of it is slightly different around the throttle body area?
  3. G60Dub
    G60Dub Forum Member
    Angus
    Here's an early type: Note that the taper from the TB along the rear of the plenum is sharper than a late model.
    EDIT: I think there is also more a more generous inlet radius into the individual cyliner runners on a late manifold.
    Yep seems so; I just dragged these out:
  5. G60Dub
    G60Dub Forum Member
    Angus
    ooops... [:$] Did I pinch you piccy?
    no not at all, your pic wasnt showing for me so i fiddled with the address till it did and posted it back up :)
  7. LregG
    Cheers guys, just to let everyone know, the early type manifold creates bonnet clearance issue on a mk2
  8. tshirt2k
    tshirt2k Forum Junkie
    Herts
    I've got a late manifold available, With isv. and all associated bracing brackets to bolt onto the back of the head ;)
  9. LregG
    I won one on eBay for 31 delivered thanks :-)
  10. LregG
    Here's the differences
    the top manifold is the later type in the above pic, as you can see, the runners are somoother to the plenum and the throttle body mounting plate has been twisted anti-clock slightly...
    The plenum chamber entrance angle finishes on the start of the H of the DOHC-16V on the early but the later one (shown at the bottm on this pic) finishes at the 6.....
    The later type (bottom on this pic) has a shorter plenum and the rear mounting hole closest to the throttle body is in further than the ealry type meaning a later type exhaust heat shield to inlet manifold support bracket will be needed. There are also two additional vacuum take offs on the later type meaning they'll need to be blocked off if fitting to an early typr engine
  11. Rusty Dan Forum Member
    Sorry to drag up an old thread but how do both inlets affect mounting to a KR head?
  12. Toyotec
    Russ,
    Bolt on as per Seat Ibiza/Toledo 1.8 ADL.
  13. Rusty Dan Forum Member
    Thanks Eddie :thumbup:
