ECU and Injectors
Discussion in 'Throttle bodies & non-OEM ECUs' started by Gentlefoot, Dec 28, 2005.
  1. Gentlefoot Forum Member
    I've done it finally. Just ordered an ECU, some injectors and throttle position sensor for the mkII.
    Its still expensive but the engine will finally run to its full potential. Seems ridiculous, having spent a lot of money on cams, head etc not to spend this extra bit to get it producing what it should.
    200bhp ere we come! Can't wait for Brands in Feb.
  2. Gentlefoot Forum Member
    If anyone has put TBs on their MkIII, I'm looking for someone to buy the fuel rail and TB from. Name ya price.
  3. altern8 Forum Junkie
    Cocos (Keeling) Islands
    badger bill sells them good service too
    http://www.badger5.co.uk/
    or u can use a 20v one i belive
    what ecu and injectors did you go for
  4. Gentlefoot Forum Member
    Going to use the Emerald. Getting the injectors from the US. The ones I'm getting are Bosch. Slightly bigger than the ones in the MkIII 2.0 16V. They flow enough fuel for 220bhp at 80% duty. Should be fine. Not expecting to get much over 200 brake.
  5. Gentlefoot Forum Member
    Managed to find the stuff I need for 175 + deklivery. Think I should be paying less. Anyone got any of these bits:
    Mk3 2.016V
    Inlet manifold - upper and lower]
    Throttle Body
    Air box
    Fuel Rail
    Injectors (only really need 1 of them)
  6. GVK
    Ju sent me a pm on another forum about this, you have to be careful which ABF manifold you use on a mk2 as some don't fit.
  7. Gentlefoot Forum Member
    He mentioned that. Not having much luck. Just phoned about 30 breakers yards. Nothing!
    Anyone know of any VW specialist breakers?
  8. GVK
    Did you contact ChrisP as I suggested?
  9. Gentlefoot Forum Member
    Turns out that 175 includes a set of injectors and is all of a sudden looking more attractive. I may try ChrisP though anyway.
    You won't believe this. Golf just passed an MOT emissions test! I'm gobsmacked. Had to lean it off and advance the timing but not by too much.
