itb injector size?
Discussion in 'Throttle bodies & non-OEM ECUs' started by steve G, Nov 27, 2007.
  1. steve G Forum Member
    can any body give me a clue on what size injectorsi will need to get the best from my abf 2.0 16 v?
    engine spec.
    balanced crank
    lightened&balanced flywheel
    forged H section rods
    forged pistons.12.5-1 comp ratio
    man in the shed head,stage2(ie fully ported but remaining standard size valves)
    shrick 260&268 cams
    cat cam vernia wheels
    jenvey 45mm throttle bodies with omex ecu
    pipercross large foam filter
    4 into 1 manifold
    2.5 inch stainless exaust
    help greatly appreciated.
    cheers steve:)
  2. Toyotec
    You would need to give us max rpm and maximum predictied HP@ rpm at sensible AFRs.
