ITBs and dipstick position.
Discussion in 'Throttle bodies & non-OEM ECUs' started by Ess Three, Sep 13, 2009.
  1. Ess Three Forum Member
    Aberdeenshire, UK.
    Folks,
    For those with 16vs on ITBs: how did you get round the dipstick being in the way of the ITBs?
    Which way did you move it?
    The 'dipstick' in charge of test fitting (me) decided to try to arc it forward to make room...which resulted in me having no level measurement at all possible despite knowing the oil was up at Max.
    I tried to bend it back and made a pig's ear of it...ending up with a dipstick tube that the dipstick doesn't want to go into.
    So, a new dipstick tube is required...and I don't want to wreck this one...so is the trick to bend it up towards the head, or down towards the front...as down doesn't seem to work?
    Anyone help?
    Thanks,
    Glen
    Mine is pushed towards the engine on non-DTH bodies / long-ish inlet mani.
    The dipstick corners are profiled to more of a point, to help it find its way.
  3. Ess Three Forum Member
    Aberdeenshire, UK.
    Superb! Thanks Chris...
    I had another look and assumed it would need to go up towards the head, but wanted to check before I give myself another self-caused problem to resolve.
    I had not considered profiling the actual dipstick - but will do so.
    Cheers.
  4. A.N. Other Banned after significant club disruption Dec 5th 2
    Check my build thread if you're using DTH - that's how mine worked.
    Second from bottom:
    Orange dipstick top is just visible, behind injector 2, next to the airbox:
  7. Ess Three Forum Member
    Aberdeenshire, UK.
    They help a lot...thanks Chris.
    Where is your build thread? I had a quick look and can't see it (only managed a quick look...at work!)
  9. Ess Three Forum Member
    Aberdeenshire, UK.
    Excellent! I'll start reading when I get the chance. Ta.
  10. Brookster
    M1 J40
    Mine is fine, as you can see below.
    between no2 & no3 trumpet.
  11. abf"d mk1 Paid Member Paid Member
    cambridgeshire
    Going to attempt to bend mine backwards towards the engine tomorrow, got a little pipe bender which i hope to use if i can fit it in. Also i have got a dipstick from an old ford crossflow engine which is a bit like a curtain wire, very flexible which may help.
  12. abf"d mk1 Paid Member Paid Member
    cambridgeshire
    Did it, had to remove grill, rad and some hoses, bender fitted in with a few thou to spare,
    actually it didnt but i made it. Didnt want to remove dipstick tube as im sure it wouldnt have fitted the same afterwards, hopefully pictures will show
    The little alloy bit on dipstick i knocked up with only hand tools to act as locator and stop anything going down the tube
  13. Brookster
    M1 J40
    i thought you had DTH Throttle bodies ?
    i would get a pro alloy inlet manifold made, you will get much better flow with one fitted.
    i bent mine back without a pipe bender worked fine.
  14. rubjonny
    on the abf dipstick the plastic bit is angled forward, might help?
  15. sambo Paid Member Paid Member
    How do Glen,
    on my mk2 with bodies iv just heated up plastic part with heat gun and shaped it as required for god clearance, let it cool, job done
  16. Ess Three Forum Member
    Aberdeenshire, UK.
    Hello stranger!
    That's another option I never thought of...cheers!
    I'll have a bash at sorting things when I get back from offshore...hopefully to collect a freshly MOT'd Mk3 with a new dipstick tube fitted!
  17. altern8 Forum Junkie
    Cocos (Keeling) Islands
    That works fine
