Mk2 Scirocco Track Car
Discussion in 'Members Gallery' started by Deako, Apr 25, 2011.
  1. Deako Paid Member Paid Member
    ReddiWraps
    Some of you know ive been hankering for another VW of some kind. "Ahhh.....missing Dubs" being the thread that started it all.
    Well, i was going to try and keep this from the forum until Curborough, but decided to let the cat out the bag. A few people have already seen the car, as i asked for both advice and guidance on it before i made the commitment to purchase it.
    Sadly, the car was located 290 miles drive away in Scotland, so a quick day trip to view was out the question.
    The car was prepared back in 2000 as a Tarmac Rally / Sprint / Clubman event race car. It has been used at various events, at stage rallies. Notably Kames. The owner knew Bill Brockbank, Nick Wilson and Chris Eyre from Kames. However, it only covered a couple of hundred miles a year and was mostly garaged. Back in 2007 the owner took it off the road, and didnt get it road legal until Feb this year, to prepare the car for sale.
    So here are some pics of the car as advertised.
    So, when the car was home and in the garage. I set to it with the hair dryer and my poor fingers. I spent around 2-3 hours de-stickering the car on the first night. However, all was not pretty under the stickers. It appeared as though scuffs, and badly repaired paint had been completely hidden by the stickers. Disaster. [:^(]
    The passenger door was covered in skims of filler. [8(]
    The day after, i decided to hit Halfords with an action plan. And bought 60 of stuff to give the doors a quick fix "Once over". I have never sprayed anything other than an eyebrow spoiler in the past, but decided to give it a go.
    The doors were given a sanding, filling, sanding, primering and top coat. The finish isnt perfect. But its way better than what was there before. The car is only a track car, but i have decided that eventually the bodywork will get a full repair and respray at some stage. Not essential at the moment, as i just wanted it to look a bit better.
    The paintwork was given some wet sanding and here is how the car looks now. There is clearly a colour difference sadly, but still. Temp job and all that. :thumbup:
    Im still happy that it looks a lot better than scraped and peeled paint from bad repairs and hidden damage.
    All tucked up. [:*:]
    Huge garage, but stupidly small doors. Meaning the car has to be parked quite close to one wall. God knows why it wasnt designed with central doors.
    More pics on my Photostream here: http://www.flickr.com/photos/lukedeakin/
    So what are the specs:
    Volkswagen Scirocco GTi, 1.8i 8V, 128BHP, MSA-RAC Log-Booked Tarmac Rally Car.
    Chassis:
    Strengthened Stitch Welded Shell
    Safety Devices Roll Cage
    OMP Front Upper and Front Lower Strut Braces
    Fully Poly-Bushed Suspension
    Spax 14 Point Adjustable Rear Shock Absorbers
    AVO Adjustable Coil Over Front Shock Absorbers
    AVO Front and Rear Coil Springs
    2 Sets of White Sebring Alloy Wheels
    1 Set of Yokohama A038 Tyres in Very Good Condition
    2 Used Michelin N20 Competition Tyres and 2 Yoko A520 Tyres
    Strenghtened Rear Axle Mounting Points on Chassis
    Front and Rear Anti-Roll Bars with Poly-Bush Mountings
    Strengthened Bulkhead at Brake Servo
    Strengthened Floor at Seat Mountings
    Stripped and Lightened Doors with Poly-Carbonate Side Front Windows and Sliders
    Interior:
    OMP Eco Competition Seats
    5 Point Harnesses
    Navigators Map Light and Foot Rest with Horn Push
    Spare Wheel Mounted Fuel Pump and Fuel Accumulator
    Kuterlex Plastic Coated Copper Internal Fuel Lines
    Internal Stainless Braded Brake Lines with Wilwood Adjustable Lever Brake Bias Valve
    Short Throw Gear Selector Mechanism
    Engine:
    Origin of engine from a Mk2 Golf GTI. B registration.
    Ashley Competition Exhaust System with 4 into 2 into 1 Heat Wrapped Manifold
    Audi GT Large Venturi Throttle Body with Modified Manifold
    Baffled Sump with Windage Tray Sump Gasket
    Mocal 256mm x 12 Row Oil Cooler
    Green Cotton Induction Cone Air Filter In Front of Radiator
    Samco Coolant Hoses
    7mm Durallium Sump Guard
    Safety:
    Battery Cut Off Switch
    Plumbed In Fire Extinguisher
    T Pull Battery Cut Off and Fire Extinguisher System
    Fibreglass Fuel Tank Guard
    Alloy Bulkhead Fitted Over Spare Wheel Well
    Brakes:
    Hydraulic Handbrake Cylinder Fitted (not connected)
    Pagid Sport Brake Materials
    Front Grille Mounted Air Ducts for Front Brakes
    256mm Front discs (Audi origin)
    The engine was rebuilt with new valve stem seals, new gaskets, new timing belt, new water pump, remanufactured alternator, new coolant flanges and elbows, the gearbox had new clutch kit, spigot shaft bearing, new push rod actuator and driveshaft seals.
    Future Plans:
    Well, eventually i would like to swap the power unit for a decent 16v engine. Some more lightening. Finish the rest of the Lexan windows. Composite seats instead of the tubular framed seats. Maybe some more work on the cage. I would like to have a proper harness bar welded in to the rear backstays as well.
    For now, the car will probably only get a couple of outings this year.
    Let me know what you think. :thumbup:
    Thanks to Chris Eyre for advice and danster for stupid Scirocco based questions.
  2. danster Forum Addict
    [8D] Cool car.
    :clap: A fine choice.
    :hug: Rocco club gets another member.
    :thumbup: 8V too.
  3. afbiker02
    Bury St. Edmunds
    Looks good Deako, 8valve ftw:thumbup:
  4. mat-mk3
    mat-mk3 Administrator Admin
    Bristol
    Looks pretty tidy from the pics! Would never have thought it would be a Rocco!:lol::clap:
    Curby deadline met [:*:] :thumbup:
    Look forward to seeing it. Do you know if by chance the owner had co driven g-wagen's Mk2 Golf rallycar anytime?
  6. Deako Paid Member Paid Member
    ReddiWraps
    Cheers Chris. He knows g-wagen well but i dont think he has co-driven it. That car sadly dropped a valve IIRC is currently being rebuilt and will be then sold on afterwards according to Colin. G-wagen also owns land rovers by the looks of things, hence being involved with Gibsons. There were plenty of pics on the wall of an off roader with g-wagen on the side.
  7. 16valver Forum Member
    Looks smart in white!
    Have not seen it out and about up here. Did the guy use it at Knockhill much?
  8. jamesa Forum Junkie
    Abz
    :thumbup:
    ... + Quaife ATB ?
  9. wadders
    wadders Forum Member
    Brighouse, West Yorkshire
    Car looks good, even better after a bit of tidying!
    Good to see you were being supervised with the hairdryer...
  10. Mike_H Forum Addict
    Looks like a good start point. A bit more power, a bit less weight (std door cards are heavy, y'know) and a proper gearbox would turn that into a quick car.
    EDIT: That doesn't mean you need carbon fibre ones though :)
  11. NicD Forum Member
    Looks a good starting point, shame about the damage hidden with the stickers.
  12. shaz8389
    shaz8389 Forum Junkie
    Get the Chris Eyre blue and white paint job for a laugh.
    Looks spot on though, nice to see you've gone back to the dark side.
  13. Deako Paid Member Paid Member
    ReddiWraps
    He mostly did Stage tarmac rallies and msa organised days at Kames.
    Yeah, lol. :lol:
    Best way to replace the door cards on a Scirocco? The doors are more contoured than a Mk1/2 Golf, where flat piece of poly is fine. The innards of the door were lightened a little.
    Boat shoes not necessary. :lol:
  14. sparrow Paid Member Paid Member
    Leamington Spa
    Looking forward to seeing it next week.:thumbup:
  15. Deako Paid Member Paid Member
    ReddiWraps
    Went to the DVLA to transfer the cherished plate off the Clio. ;) It probably wont go on the Scirocco, it wont have enough outings to justify it really. But it may make its way on to another VAG car once the Clio is gone! [:D]
  16. steve r
    steve r Forum Member
    Nice looking car, look forward to seeing it in action at Curby :thumbup:
  17. Deako Paid Member Paid Member
    ReddiWraps
    Cheers Steve. If i can get under 30s i will be happy. Under 29 and i will be joyous.
  18. Richard Mk2
    London / Bucks
    Looks nice Deako :thumbup:
    Good to see something different rather than the usual MK1 / MK2 Golf track cars!
  19. shaz8389
    I think he only takes them off for track days! They made an appearance at my BBQ and all :lol:
  20. vw_singh Events Team Paid Member
    That looks really smart. Good choice!
    Gurds
