Part numbers for Mk2 Golf oil pressure switches?
Discussion in 'Electrical' started by the loop, Jun 3, 2014.
  1. the loop Forum Member
    I've identified an oil leak coming from at least one (of the two) oil pressure switches on top of the oil cooler of my 1990 16v GTI. I plan to replace the pair of them but I'm struggling to find out the part numbers for each.
    I did find this diagram but I'm struggling to make much sense of it: http://www.partsbase.org/vw/golf-go...h-switch-for-reversing-light/#p-vw-056919081e
    Presumably there are o-rings between each switch and the oil cooler which should also be renewed? And finally is there a torque specification, or is the answer as tight as it needs to be not to leak? :p
    Thanks!
  2. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    From a recent thread:
    They seal with a little metal (copper?) washer that should be supplied with new switches I think. Not sure on torque, shouldn't need a lot. Genuine from dealer/TPS recommended as they're not that expensive.
  3. the loop Forum Member
    Thank you Pete!
