Speaker wiring
Discussion in 'Electrical' started by cormac81, May 4, 2024.
  1. cormac81 New Member
    N.Ireland
    Hi folks
    I am replacing the dash speakers on my 85 gti but the connections on my loom and the new speakers are different. Any tips how I can adapt the fittings to suit?
  2. RichardDarrenB Paid Member Paid Member
    Make an adapter loom with male spades on one side and female on the other?
    cormac81 likes this.
  3. Zender Z20
    You can get ready made ones, don't recall now where these came from but likely eBay or similar...
  4. cormac81 New Member
    N.Ireland
    Had a quick look on ebay but couldn't see anything that is the same shape as my loom connectors but I will keep looking.
  5. Zender Z20
  6. cormac81 New Member
    N.Ireland
  7. watercooled Forum Member
    Nelson,New Zealand
    Long as it's not the crazy Active system you will be fine,mine was a mare and had to test and test again and miss match colors for my Blaupunkt head unit loom and JBL speakers using the factory black and brown factory plugs ,worth it as sounds good but no interest in doing that again.
    You don't need those silly plugs ,chop them off and buy the right crimp female connectors to suit your speaker pins,the wiring is long enough @ speaker end top dash and door panels ,but applies to rear speakers also.
    Cheers.
    PhilRyder likes this.
  8. PhilRyder
    Agree with above, cut the plugs off and put spades on, easy peasy.
  9. rubjonny
    nooooo, dont cut the original vw loom. it makes my wiring OCD sad
  10. RichardDarrenB Paid Member Paid Member
    Couldn't agree more. Next people will be suggesting the OP uses scotchlocks ;)
