weight difference 8v and 16v heads
Discussion in 'Engines' started by RobT, Dec 16, 2009.
  1. RobT
    RobT Forum Junkie
    Cheshire
    does anyone have a built up 8v and 16v head that they could weigh for me? (head casting plus valves / followers / cams / cam cover)
    I am interested to know the weight difference between them as I cannot imagine it is that much
    The reason is that I have just been told that 16V engines might upset the balance of a formula car that is designed to run with an 8v engine in it
    Bottom ends are essentially the same.
    Cheers
    Rob
  2. G60KG
    G60KG Forum Member
    at work 'working'
    built up 16v head without manifolds weighs 26.3kg on my digital scale. Dont have an 8v lying around.
  3. RobT
    RobT Forum Junkie
    Cheshire
    Thats mint info - thanks a lot - does that include cam cover?
  4. G60KG
    G60KG Forum Member
    at work 'working'
    no worries yes cam cover included.
  5. RobT
    RobT Forum Junkie
    Cheshire
    Anyone got a built up 8V head then with cam cover?
    Whats the betting? 18kg?
  6. 2dubnick Forum Junkie
    Worcester
    i was thinking 18kg, could do a g60 one with either std or g60 cam cover built up head with plugs sprocket and guide tomorrow if no one else comes through, thou my scales cant be considered accurate. I supose more material could be taken off a race 16v head though?
  7. RobT
    RobT Forum Junkie
    Cheshire
    +/- a kg will suffice for what I am thinking about
    cheers for help
  8. 2dubnick Forum Junkie
    Worcester
    16/17kg with standard cam cover, really unsure of my scales though, just a cheap pair of bathroom ones.
  9. RobT
    RobT Forum Junkie
    Cheshire
    ta - so 9-10kg difference would be a good estimate
  10. 2dubnick Forum Junkie
    Worcester
    surprising amount I think, someone might come along who has both heads and a decent set of scales to give you better figures but at least it gives you a idea.
  11. Tristan
    I would say a Formula driver , if really "on it" would notice that . Bearing in mind that it's a significant mass , and one of the highest points of the car .
  12. A.N. Other Banned after significant club disruption Dec 5th 2
    It's got to be worth a call to Jim Morris - he wouldn't have built his with an inherent & unsolvable handling issue.
    Worst case, he's only had to adjust the suspension settings.
  13. Mike_H Forum Addict
    Jim's 'VW' engined cars are 8valve IIRC.
    The 8v number is about what I remember from shipping an 8v Mk3 head. I'd have said 16-17kg with the alloy cam cover.
  14. RobT
    RobT Forum Junkie
    Cheshire
    Jim Morris is the chap who has brought this to my attention - I am very suprised that this littkle amount of weight would have a very significant effect on a cars handling - this could easily be the difference between two drivers
    Interesting. IIRC Jim parked his Ralt up in 2007...
    It's high up weight for a single seater, I'd agree - force x distance - but I'm surprised a power gain and suspension tweaks don't combine well.
    Then again, the weight of a driver is a much bigger proportion of overall weight in single seaters. Two different weight components to factor in.
  16. RobT
    RobT Forum Junkie
    Cheshire
    Jim parked up his Ralt to go FF1600 racing.
    There are loads of Ralts and the like on the hillclimb/sprint circuit with all manner of 16Vs in them - Vaux redtop is common but others also.
    But Jim know's his onions so I am considering his comments seriously.
  17. Mike_H Forum Addict
    FF1600 is sold now, and he's bought something else... older... cooler... with more bodywork for Lifeline stickers.
    I think the Ralt is still there, and still an 8v Judd/Brabham lump.
  18. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    I think VW quoted a 7kg increase with the 16v head, unsure if that was the bare casting or built... but in the ballpark of yr estimate Rob.
  19. iguana Forum Member
    Samoa
    Had a fair few of each head floating about, just 16v now tho but when lifting them about felt v significant diference in the 2, def in the 10kg area on the forearm weighometer
  20. VDubbaY Forum Member
    South Wales
    Weighed an 8v mk3 gti head, built-up, without manifolds = 15.5 Kg
