ayp - mk2 ce2 wiring, help needed
Discussion in '1.8 & 1.8T' started by benthejettaman, Jan 21, 2014.
  1. benthejettaman Forum Member
    some where in the uk
    hi peeps trying to build a mk2 ayp loom going to need help with a couple of pins outs and connections at the mo, if not shortly
    to start with does anyone know the pin outs for t14b
    so far i have got
    t14b/2
    t14b/3
    both go to fan control unit so not needed in a mk2
    can anyone help with the others plz
    thanx in advance, barry
    ps i would check against the other half of loom but that in my bro's garage 60 miles away
    i have the seat ibiza diagram in my sig, you'll also need the round plug pinout in there :)
    if you're really strugglign I'll decode it for you tomorrow as I'm leavign work now :lol:
  3. benthejettaman Forum Member
    if you could that would be great, ive looked at both 6k1aqxaypecu and also 6k1 basic equipment diagrams in your sig and can only find reference to t14b pin 2 and pin 3 cant find any other pin outs unfortunatly.
    ps, its an ibiza loom
  4. fife-flyer CGTI Regional Host
    Fife Scotland
    Is it not T14a you should be looking at?
  5. benthejettaman Forum Member
    yeah figured out t 14a, just need to make sure there is nothing in 14b i need
    T14b is the radiator fan control unit, you can bin off all the wires to this and just use the factory mk2 fan wiring instead. you would only really want the fan controller if runnign aircon or if it was a 5/6 cylinder to control the electric coolant pump
    T28
    1 - crank sensor pin 3 - ecu pin 82
    2 - crank sensor pin 1 - ecu pin 108
    3 - fuel injector #4 pin 2 - ecu pin 88
    4 - fuel injector #2 pin 2 - ecu pin 89
    5 - crank sensor pin 2 - ecu pin 90
    6 - oil pressure switch - G2/10 or G2/11
    7 - coilpack #4 pin 3 - ecu pin 94
    8 - coilpack earths - battery -ve
    9 - coilpack #2 pin 3 - ecu pin 95
    10 - fuel injector #1 pin 2 - ecu pin 96
    11 - fuel injector #3 pin 2 - ecu pin 97
    12 - knock sensor 2 pin 3 - ecu pin 108
    13 - knock sensor 1 pin 2 - ecu pin 99
    14 - coilpack #1 pin 3 - ecu pin 102
    15 - coilpack #3 pin 3 - ecu pin 103
    16 - knock sensor 1 pin 3 - ecu pin 108
    17 - coil live feed - G1/10
    18 - knock sensor 2 pin 1 - ecu pin 106
    19 - knock sensor 1 pin 1 - ecu pin 107
    20 - ecu sensor earth - ecu pin 108
    21 - throttle body pin 6 - ecu pin 91
    22 - throttle body pin 5 - ecu pin 118
    23 - throttle body pin 4 - ecu pin 84
    24 - throttle body pin 3 - ecu pin 117
    25 - throttle body pin 2 - ecu pin 83
    26 - fuel injectors pin 1 - Z/1
    27 - throttle body pin 1 - ecu pin 92
    28 - N249 pin 2 - ecu pin 9
    T14a
    1 - fuel pump power for engine loom - G1/8 or Z/1
    2 - N112 valve pin 2 - ecu pin 105
    3 - N75 pin 2 - ecu pin 104
    4 - cam sensor pin 2 - ecu pin 86
    5 - ecu temp sender - ecu pin 93
    6 - dash temp sender - G1/3
    7 - PAS switch pin 1 - ecu pin 49
    8 - PAS switch pin 2 - ecu pin 50
    9 - earth for dash temp sender - head or battery -ve
    10 - speedo sensor pin 1 - G2/4 if using
    11 - speedo sensor pin 2 - G1/11 if using
    12 - speedo sensor pin 3 - earth if using
    13 - inlet temp sensor pin 1 - ecu pin 85
    14 - cam sensor pin 1 - ecu pin 98
    benthejettaman likes this.
  7. benthejettaman Forum Member
    cheers jonny your are a star as normal, you have also confirmed my wiring is correct
    thanx again
    barry
  8. djenks New Member
    have just had a loom done for 1991 mk2 16v golf gti to fit ayp dbw setup it starts idles . Throttle body has full movement with pedal but bares absolutely no affect on rpms I’m stuck also has no signal from ecu for fuel trigger. with what to do has something been missed ? It’s had o2 post cat sensor removed Sai removed ‘brake ‘clutch abs ‘and wiring for these parts removed too etc removed any help would be very much appreciated. My first ever time on here hope I’m relatively clear it’s ce2
    Sorry if I’ve posted wrong place etc too
  9. rubjonny
    did you do the loom yourself or was it done by someone else? the loom builder woudl be the best person to ask as they'll know what exactly was done.
    heres a full ibiza -> ce2 guide:
    https://www.clubgti.com/forums/inde...-general-fusebox-plug-reference-guide.285928/
    I would start by checking fault codes and scan through ecu measuring blocks make sure all is well there. if its not been wired in then its the grey/white on ecu pin 43 which needs to run to diagnostics port pin 7, then give the port live on pin 16 and earth pin 4.
    for fuel relay trigger this is a green/white wire from ecu pin 65, if you want to use the factory fuel relay on the fusebox it goes to g1/3
