hi there, im trying to use 256mm hubs and driveshafts from a corrado, to mate with a 2.0 16v 9a engine also from a corrado. planning to use an 020 gearbox as it is going into a mk2, am i right that i can only use a 020 16v box due to teh flange sizes? if so, can it be any 16v 020 box? i have heard people talking about different input splines and 90 & 100mm flanges, i would be grateful if someone could explain the differences between the 8v and 16v boxes to me. Cheers Scott
I Think the input shaft and the drive flanges are both bigger on the 16v box and the ratios are different. Edited by: loadsavalves
Both will have the same flanges. Gear ratios will be different, but you'll need to use the clutch friction plate to match your gearbox. Everything else is a straight fit......
so all 020 8v and 16v boxes have the same sized input and output flanges? meaning that i could potentially connect 16v driveshafts to an 8v box, but would have to use an 8v clutch? i thought some boxes were 90mm output and some 100mm. cheers scott
Hmm, according to this: http://www.scirocco.org/gears/ it looks like it should be the 16v's, 8v gti's, and early mk3 8v's Could be wrong though.
found this today: http://cars.vwsport.com/gears/index.html im not bothered about haveing the same ratios, just want a box that will take a 210mm 16v clutch and that will connect to the driveshafts i have. is the 90/100mm measurement, the diameter of the output flange, i.e. distance between two oppostie bolt holes? or a different measurement? cheers
