Has anyone got an 020 clutch push-rod lying about? I could do with someone measuring a good one to check against mine... Does 340mm long sound right? Cheers.
feckinell he's alive! ive got a couple up at the unit,ill pop up and measure tommorow unless someone else can help first? neil.
i asked because i also got anabf in a mk2 and rod seem'd too short, did try a new one and still too short, just welded a bit of weld to the end to make it longer.
I had one on the kitchen draining board...... no tapemeasure, but it's almost exactly the same length as my cock, which would make it around 340mm. Nah, I did actually measure it - 340mm from tip to tip, from an 8v Gti ACD code box......
You can't just turn up after *months being away* with a techy question like that without saying what you're up to Edited by: Chris Eyre
Top secret, I know what he's planning. he's got a zimmer with a feek off big nitrous bottle! It'll do the post office in as little time as it takes for an old fart to wet herself
