02a and 02j issue, please help
Discussion in '1.8 & 1.8T' started by vwbobby, Dec 6, 2013.
  1. vwbobby Forum Member
    Hi all,
    I have a 1.8T BAM engine conversion and a 02a gearbox in my corrado. I was looking in fitting a 02j gear linkage to the gearbox and it seems to be different.
    Is there a special way of fitting this or do I need to modify it in anyway.
    Please anyone can advise help on this will be a big help and if anyone has any pics will be great as well.
    Thanks
    Bobby
  2. Jon Olds Forum Junkie
    There is 1mm difference in the bottom spigot diameter. 02J is bigger. They are not interchangeablce unless you drain the oil out , drop the two 13mm bolts out of the bottom and change the oval shaped lower mount as well
    Jon
  3. vwbobby Forum Member
    What do you mean by the oval mount, are you talking about the one on the gearlever side in the cabin?
  4. Jon Olds Forum Junkie
    At the bottom of the tower on the lower face of the box is the oval flange. This is paired in size with the tower. You will get very oily if you remove it with the oil in.
    Havent done one in situ, but Ive just built two 02a/j combos, so I think I understand your issue.
    Jon
  5. vwbobby Forum Member
    I must sound stupid here, sorry if I do mate.
    I am still confused.
    Basically I have the tower and cables of a 02j and a 02a gearbox with the o2a linkage on the box.
    So will I need a 02j linkage on the gearbox side in order to fit all this?
  6. Jon Olds Forum Junkie
    Sorry, its my mistake, when you said tower I thought you meant the other end, at the box.
    Mine uses a 02a tower/cables onto an 02j box.
    Havent tried an o2j tower, although my gearchange is so poor, I would if I could
    Jon
  7. Gup16v Forum Member
    West Midlands
    to fit a 02J tower
    you need the gear selector - the cables and the tower.
    the part which drops of is on the bottom, its normally a big VW stamped oval shape plug and has two bolts through it.
    Some need them changed others don't.
    02J gear selector fits 02J Shifter Tower
    02A gear selector Fits 02A shift tower
    they dont iirc work with each other.
  8. Richard Mk2
    London / Bucks
    Basically, number 8 in the diagram needs to be changed ;)
  9. vwbobby Forum Member
    Cheers Rich that is a big help mate, thanks a lot.
    Did you here I a picking up a mk2 Jetta tomorrow mate
  10. Richard Mk2
    London / Bucks
    No worries mate :thumbup:
    I haven't heard that yet ! How many VW's do you want Lol! ;)
  11. vwbobby Forum Member
    lol, I got the veedub bug mate, lol.
    my black rado is going and Jetta is coming
  12. Jon Olds Forum Junkie
    My car (now) has an 02a tower connected into an 02j box!
    Jon
  13. vwbobby Forum Member
    Yeah mine would be the other way round if it is possible to do?
  14. tshirt2k
    tshirt2k Forum Junkie
    Herts
    Bottom bit doesn't always need to be changed. Depends on the box you have.
  15. peterg60 CGTI Regional Co-Host - Birmingham & Midlands
    birmingham
    my 02a box out of a mk3 16v golf cda code bottom didnt need changing 02j tower fitted straight in
  16. vwbobby Forum Member
    I am not too sure what the code is on my box, where can I find this?
  17. Richard Mk2
    London / Bucks
    Looking down on the top of the gearbox, you'll see a small plaque just underneath the tower. :thumbup:
  18. vwbobby Forum Member
    Cool will have a look and let you guys know
    Cheers
  19. tshirt2k
    Herts
    DPA doesn't need it either.
  20. Gup16v Forum Member
    West Midlands
    ASD doesn't either
