Hi all Does an 02A box fit my 91 8 valve golf? what are the differences/benefits over the 020? cheers
02A is a cable change box IIRC, stronger than a rod change 020, but a rod change should be sufficent for your power output Andy..Easy enough swap to the best of my knowledge.. Cable change boxes feel cumbersome & slow in comparison to an 020 with a new bush kit & quickshift.. Do you have problems? If so, join the club
no problems with box as such apart from weeping or should i say crying there eyes out [:^(] drive shaft flange seals, getting new clutch next week as well as new suspension, and bushes, thought i might get a different box but will leave as is and get seals done at same time. sorry to hear your having problems mate. do you run a helix clutch or would that be overkill on mine?
Yes mate, mine is a (dead I think) Helix [:^(] or the 'box has bitten the dust ...Got to investigate fully tomorrow The flange seals did used to weep a bit, but I never got round to them as they were never too bad. Id just do them & go for a new 8v friction disc with the existing 16v pressure plate..
