Od is 68mm and id is 59.3 ish Can find plenty of 02M kits, but struggling to Find 02A or J I have lots of 020 stuff Job stopped for want of a 1.05 or 1.1 mm TIA Jon
Have you tried Darkside developments? https://www.darksidedevelopments.co.uk/products/02a-transmission-differential-installation-kit.html More Northern price https://www.darksidedevelopments.co.uk/products/02a-02j-differential-shim-kit.html
Thanks. Back ordered with dealer now. 1 week to 2 months was the quote. 'none in uk' I am after a little more help on a related issue now; 02J removing 5th gear synchro hub (argentinian made box) Heat and an adapted mechanical puller has so far failed to shift it They are normally tight, but this one is ridiculous.. See piccy Anybody got any suggestions?
Doing another 02J box now. Looking to invest in another set of 3 leg pullers. Will a 5 tonne set pull 5th gear synchro hub off, or an 8 tonne? Looking at MATRA, Sykes Pickavant, Sealey, Kukko What have you bought guys? Regards Jon
Do not use ‘legged’ pullers in the drive gear, sure way to chip teeth. For the smaller driven I have a home made jobbie with thin legs. Vw do the shims separately
Understood, agree. Tricky job though.. Made something, but its not pretty. Job now complete, ready to go into my A3 Thanks Jon
