the starter motor has started making this horrible noise ater the engine catches and ignites, as if it isnt switching off when the engine starts. it only used to do it now and again but it makes the noise everytime i start the car now. is there a way to fix this or do i need to save up for a recon starter??? cheers rich
Stands a chance that the solenoid is on its way out. Its engaging with the flywheel but not disengaging quick enough.
got ya. does anyone know if solonoids are interchangable between o2a and mk2 8v as i think ive got a starter or 2 in the shed of an 8v.
its the end with the cog on needs cleaning up with a wire brush..maybe some wd40 had the same prob on the g60
Hi Ya. Get the starter out and give the shaft and gear a good dose of wd40. In fact, pull the gear by hand and spray some wd40 behind the bearing. Also, test it with a 12v battery BEFORE fitting it back in.
