i am finally making a start on my gti restoration and one of the main things i desperatly need to do is rebuild the engine and replace several worn components. when i put it all back together i wanna use better parts (cams, valves, tappets etc) so suggestions on what to combine in order to achieve best power and response, with out spending a small fortune.... also where can i find a good guide to doing the rebuild?? i also have to sort out braking and suspension, so again...suggestions please (will be using adj. camber) cheers, andy
