1.8t cam sensor pin out for S60 DTA info req'd
Discussion in 'Throttle bodies & non-OEM ECUs' started by badger5, May 26, 2008.
  1. badger5
    Does anyone (toyotec) have the pin out of the stock 1.8t cam sensor pin outs?
    wiring my s60 up.. assuming hall effect cam sensor, but does anyone know the pin outs for the sensor?
    thanks
    bill
  2. bens_cab Forum Junkie
  3. badger5
    3 pins... not on that link (which is very usefull btw - thanks)
    hall effect I'm sure, but not sure on their pin outs.
  4. bens_cab Forum Junkie
    ive got a mk4 haynes but coulnt find it ill double check
    i never used mine as im running wasted spark lol
  5. bens_cab Forum Junkie
    for AGU
    brown/blue to earth
    lilac/red to ecu T80/62
    lilac/yellow to ecu T80/76
    thats waht the haynes says
  6. Toyotec
    The pins for G163 "hall sender" found on AUQ and AUM engines from may 2002 are:
    1 = 5v purple/green
    2= Return signal to PCM purple/yellow
    3= Earth brown/black
    Identical wiring pattern is found on Bosch hall distributors.
    I do not have specific wiring for AQX and AYP engines but would imagine that the above pattern will not change.
  7. Toyotec
    Also the same pattern as wiring pattern seen in thread above.
  8. badger5
    spot on.. you are da man :clap:
    although different OE wire colours on my ibiza pin out is much appreciated.
    mine for ref:
    1 - green/red
    2 - green/violet
    3 - brown
    AYP ibiza std engine
  9. badger5
    thanks guys
  10. bens_cab Forum Junkie
    tis ok
    that super 7 car is gonna be a bit nuts me thinks like you said very handy wiring info
