hi guys im just wiring up the s80 ecu and would appreciate some info on the pinouts for the vr crank sensor thanks in advance
Cant remember exactly but i think you have to use pins 2 and 3 probably white and yellow or grey Pin 2 signal Pin 3 signal earth Pin 1 shield I have it all written somewhere chris il dig it out tmrw Same goes for cam sensor
The wiring diagrams are all here: http://www.dtafast.co.uk/Downloads/Downloads_Index.htm On the S80, magnetic crank sensor is pin 12, hall is 13, and sensor ground is 21
cheers guys its at the sensor end im after, i think sambo is right as bosch sensors usually have the signal in the middle
