Hi Guys, Can the 1.8T tripoic style (108mm) drive flanges be changed for 100mm ones, to enable compatability between 1.8t (EVS) gearbox and mk2 golf driveshafts? On etka they show the drive flanges with a spring clip and centre bolt holding the cups in place. Once the bolt os remove you i guess you can use a hub puller to take 1.8T flanges out ?? The tripodic inner cv's dont fit on the mk2 drive shafts [:^(] Edited by: Mr T
are there any drive shafts that are the correct length for mk2/1.8T and will allow the use of later tripodic inner cv's ??
