1.8T without power steering - which alternator belt?
Discussion in '1.8 & 1.8T' started by Mook, May 19, 2010.
  1. Mook
    Mook Forum Member
    South Coast
    I'm going to ditch the power steering on my Mk2 with 1.8T conversion. Question is, once the power steering pump is removed, I obviously need a shorter alternator belt, but which one from which car? I'm guessing a Mk3 Golf or B4 Passat multi-ribbed belt, but which Mk3/B4?
    Cheers :thumbup:
  2. Matt82
    Matt82 Forum Addict
    GTI Scene
    basically, you can order whatever you like
    go down eurocarparts, ask for 6pk****.
    **** is the length of the belt you require in MM
  3. Mook
    Mook Forum Member
    South Coast
    I need to know what length of belt I need though to do that. Is there a standard belt that will fit straight on?
  4. Admin Guest
    bit of string and measure it up?
  5. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    take measurement with tensioner at both ends of travel & ask for something in middle!
    done that at my local factors with off the shelf result
  6. Mook
    Mook Forum Member
    South Coast
    Lovely jubbly - will give it a go.
    But should I use hemp string or baler-twine...? ;)
  7. rubjonny
    genuine vw strimmer wire obviously ;)
  8. b5byt Paid Member Paid Member
    Leicester/Loughborough
    Halfords HB925G
  9. bens_cab Forum Junkie
    Ashford kent
    i did that and spent a good half hour pulling all the fanbelts of the shelf until i found the one i wanted the staff there were not impressed i did say it as part of my job creation scheme ill let you put them all back right:lol:
  10. Mook
    Mook Forum Member
    South Coast
    Cheers :thumbup:
  11. Ditchyboy Forum Member
    Shepshed, J23 M1
    if you could let me know what you went for in the end and if it was any good that would be great mook as i need the same thing.
  12. 16valver Forum Member
    Yes...
    ...I am pretty sure that the white box on the left was the belt I ordered from VAG and was spot on for my AGU 1.8t, deleting the AC & PS
    Cant remember the part number but should be able to get it this weekend when I get home.
  13. Mook
    Mook Forum Member
    South Coast
    I got a HB925G coded belt off the shelf at Halfrauds. Fits fine :thumbup:
  14. 16valver Forum Member
    I *think* this may be the part number for the VAG belt.
    I threw the box away and can not find the invoice from VAG, but I have found a bit of scrap paper that has my shopping list of car bits on it...
    This may be it - 038903137G
    Is that a VAG part no. [:s]
  15. prof Forum Addict
    Suffragette City
    I bet it's a bit wild tho with 1.8T torque and a manual rack
  16. 16valver Forum Member
    ...and a quaife quick rack at that. Plus wide slicks and a plate diff. Got disaster written all over it I know....[:o)]
  17. 16valver Forum Member
    Just to confirm that 038903137G is the correct part number for the belt from VW
    Just found the box while cleaning out the garage :thumbup:
  18. Admin Guest
    Thanks, will make a note of that.
  19. prof Forum Addict
    Suffragette City
    get to the gym, you'll need guns of steel
  20. 16valver Forum Member
    Aye, atm, big guns seems like an easier option!
    Major ballache fitting PS on my car as I have the Autocavan pedal box otherwise I would have just gone for Corsa electric PS.
    Thinking about selling it, going floor mounted pedal box + remote servo + corsa PS setup...
    ...like I say, might be easier getting down the gym!
